MSI Radeon R9 270 Gaming Edition OC 2048MB GDDR5 PCI-Express Graphics Card @ £131.99 inc VAT
R9 Series Graphics
You’ve heard it before: no guts, no glory. Now you’ve got both. With the power to drive today’s hottest games — and tomorrow’s — Radeon™ R9 270 graphics keep you in the fight whatever the circumstances.
LET THE GAMES BEGIN
A graphics card is the single most important element for more FPS. As gamers, we understand that not just any graphics card "will do". That's why we bring you the best of the best. We don't want to bug you with noise and heat, but we DO want to give you more performance. With MSI GAMING series graphics cards you get just that.
MILITARY CLASS 4 COMPONENTS
Military Class 4 is the next step in high quality components. The Hi-c CAPs, Super Ferrite Chokes and Dark CAPs will make sure that your PC runs more stable under extreme gaming conditions.
ADVANCED TWIN FROZR IV
MSI's Twin Frozr has been the industry defining graphics card cooler. The first Twin Frozr kicked off the dual-fan trend and today MSI stays true to its dual-fan dual-slot design where others have to resort to less effective means.
AFTERBURNER
MSI Afterburner has quickly become the favorite overclocking software for media, overclockers and end-users. Because of its simple interface, it's easy to learn, but it packs a lot of powerful features like an integrated benchmark utility called Kombustor that can check your system performance in benchmarking mode, or run as a stability test.
GAMING APP
EASY TUNE, EASY PLAY - OC Mode, Gaming Mode and Silent Mode available at a click of a button. You decide!
PREDATOR
A built-in screen and video capturing tool named Predator which captures your screen as still images or videos with the push of a button and allows you to capture and record your coolest, goofiest and most awesome gaming moments on your PC!
Ultra Resolution Gaming
Leave HD in the dust by gaming on displays much, much larger. Whether using a 4k monitor or combining multiple HD monitors, you’ll get an expansive experience that’s truly out of sight.
GCN Architecture
Primed to enable astonishing performance and breathtaking image quality, making it a top choice for gamers who expect the best.
AMD CrossFire™ Technology
With outstanding performance scaling, a system equipped with AMD CrossFire™ technology keeps you fragging while everyone else is reaching for an upgrade.
AMD Eyefinity Technology
Enjoy the ultimate immersive gaming experience with innovative “wrap around” multidisplay capabilities.
AMD HD3D Technology
Play 3D games, watch Blu-ray 3D videos, and edit 3D photos on your 3D monitor, TV or projector.
AMD App Acceleration
Improve performance of everyday tasks such as Web browsing, office applications and video rendering.
AMD PowerTune Technology
Enables intelligent power monitoring to enable higher clock speeds and better performance in your favorite games.
AMD ZeroCore Technology
Allows your AMD Radeon™ GPU to consume virtually no power when in idle state.
Specifications
Interface:
PCI-e 3.0 (backwards compatible with 2.0)
Core Speed:
900MHz (975MHz Boost Speed)
Memory Buffer:
2GB GDDR5
Memory Speed:
5600MHz
Memory Interface:
256-bit
Connectivity:
2x DVI, 1x HDMI, 1x DP
Stream Processors:
1280
HDCP Support:
Yes
Max Resolution:
4096x2160
DirectX Support:
DirectX 11.2
CrossFire:
Yes
Monitor Support:
Up to 4 displays
Power:
1x 6-Pin + 1x 6-Pin (180W TDP)
Dimensions:
260 x 129 x 38 mm
Only £131.99 inc VAT.
ORDER NOW
_____
Gigabyte P34G-CF2 UltraBlade Gamer 14" LED TFT, Intel Core i5-4200H, 8GB DDR3, 750GB 5400RPM HDD, NVIDIA GTX 760M 2048MB GDDR5 - Windows 8 Laptop @ £899.99 inc VAT
The 14” GIGABYTE gaming laptop P34G features a 4th generation Intel® Core™ i5 processor and a powerful NVIDIA® GeForce® GTX 760M gaming level discrete graphics. The P34G is able to pack a high-speed 750G HDD* into its incredibly slim and lightweight body of only just 21mm and 1.67Kg. The exceptional Full HD AHVA display with wide viewing angle, Dolby Home Theater sound quality optimization technology, equipped with flagship gaming specifications is unprecedented in the history of gaming laptop. With state-of-the-art design, the P34G delivers a full throttle gaming experience. The P34G from GIGABYTE is its most stunning gaming laptop ever.
The Haswell platform 4th generation Intel® Core™ Processor is built on the 22nm architectural process making use of the latest 3D Tri-Gate transistor technology. It delivers revolutionary battery life improvement, breathtaking perforamnce, ultra-fast image / graphics processing, and many other security protection capabilities. Enjoy the breakthrough performance that you have never experienced before.
Features a high-end NVIDIA® GeForce® GTX 760M GDDR5 2GB graphics processor that supports NVIDIA® Optimus™, NVIDIA® PhysX™ and DirectX11 Technology! The P34G delivers an ultimate gaming experience even for the most heavy games. Enjoy unrivaled power with an impressive score exceeding P14, 500 on 3DMark Vantage!
Performance is the main concern when developing and creating the P34G gaming laptop. The GIGABYTE R&D team utilized highest standards for internal design as well as integrating the most powerful processor, graphics chip, and essential components into the 21mm, 1.67Kg super slim and lightweight body. Thus, making P34G the extremely thin gaming laptop on earth.
The P34G has a dual air vent design (one for CPU and one for GPU) that efficiently eliminates heat and keeps noise to a minimum. Despite the powerful features and thin form factor, the unique venting system is able to effectively keep the notebook from overheating.
The P34G masters an automatic light sensing backlit keyboard. This significant feature adjusts the light to external conditions and makes typing and gaming in dimly lit rooms and dark conditions brighter and better.
The ability to clearly hear specific sounds in a gaming environment are just a few elements of the Dolby Home Theater Audio Technology. It provides exceptional performance by effectively eliminating sound distortion, enhancing volume and reinforcing even the smallest details of sound. The result is a high-fidelity audio experience that is perfect for gaming, music and movies.
Specification:-
- Display: 14" Full HD AHVA Display
- CPU: Intel Core i5-4200H
- OS: Windows 8
- RAM: 8GB
- GPU: nVidia GeForce GTX 760M 2GB
- Storage: 750GB HDD 5400rpm
- Weight: ~1.76Kgs
- Dimension: 340*239*21mm
- Warranty: 2Years
Only £899.99 inc VAT.
ORDER NOW
R9 Series Graphics
LET THE GAMES BEGIN
AFTERBURNER
GAMING APP
PREDATOR
GCN Architecture
AMD HD3D Technology
Specifications
Interface:
Core Speed:
Memory Buffer:
2GB GDDR5
Memory Speed:
5600MHz
Memory Interface:
256-bit
Connectivity:
Stream Processors:
1280
HDCP Support:
Yes
Max Resolution:
4096x2160
DirectX Support:
DirectX 11.2
CrossFire:
Yes
Monitor Support:
Up to 4 displays
Power:
Dimensions:
260 x 129 x 38 mm
ORDER NOW
_____
Specification:-
- OS: Windows 8
- RAM: 8GB
- Weight: ~1.76Kgs
- Warranty: 2Years
ORDER NOW
