What do we think of this gaming spec?
Oh and if you hadn't guessed he wants a black/blue theme. But blue + another colour would also be good, perhaps blue with some red LED's somewhere? dunno
Get the M5A97 Evo 2.0 and an 8320. Should work out around the price. Better mobo and the 8320 you can OC to 4.2-4.4+ on it.
For that money you should be able to get an intel build.
Lovely, cheers guys for all your input so far. My thoughts on your input:
The Asus M5A97 mobo seems good, he is only ever going to have a single GPU setup so that's why I didn't go for a higher end board.
The lower end CPU makes sense - I am competent in overclocking so I agree, why not save money there.
As for the CPU cooler, I think we do want to go for a liquid cooler, primarily to give more room inside and so it looks good through the side panel :) I imagine the K2 and H80i have similar performance temps wise? Perhaps the K2 even is better than the H80i - bearing in mind I will be dusting off my overclocking hat with this build, perhaps we should look at a 240mm rad liquid cooler?
We all seem to agree the case is ok? I just picked it because it had a big window, blue LED's and I know cooler master are decent brand.
I should add that he already has a 120gb SSD in his current PC so we will be using that in this build.
@Fowler - thanks for this spec, I had written off an intel build in my mind as I never thought we could get it in budget - looks promising though and I would prefer to put a 290 gpu in it over any other card as it has the best bang for your buck for sure.
Will probably stick some led strips and bitfenix braided power cables in there as finishing touches :)
you want the m5a97 evo not just the standard m5a97!! the one i linked above.
the case is fine and if you want to go for something like the corsair h100i people say this '' will fit in the top of the coolermaster 690 II with no modding (but depends on motherboard) '' so i would go for the h80i and stick it on the back fan mount, it will be fine
edit. i wouldnt go for a 500w with a 290 get atleast a 650w so you have some room for overclocking
i second this build ^ if you went with a 770 gtx instead of the 290 you could also fit in a water cooler instead if he really prefers that, and it would run more comfortably on a 500w psu - so a better overclock and potentially save a few ££
Thanks for the continued responses :)
I see the 4670K and the FX8320 are fairly closely matched, performance wise (although the intel still beats the AMD in all but price):
http://cpuboss.com/cpus/Intel-Core-i5-4670K-vs-AMD-FX-8320
One thing to consider here though is that AMD's Mantle API has been slated to be able to utilise more CPU cores in games. Whilst this may not really kick off until more game developers use mantle in their engines, this could result in the AMD 8-core build being considerably better for gaming...
I guess only once Mantle is released we will know for sure
AMD made a lot of noise about mantle with..... Kaveri.
So it's likely the 4670K's going to see gains with mantle, who knows how it'll compare with the FX83's until it actually arrives.
I would never use CPU boss personally.
If I was looking at an R9 290, I'd want a 4670K beside it, as opposed an FX8320.
Yeah I would too, but going AMD route allows for a 290 in there just about on budget. Intel route pushes it over a little. Perhaps I will have to convince him to spend a bit more... or we could drop the kb, mouse and hdd and reuse what he has got - allowing for an intel 290 build on budget...
What is the budget as you've not clarified it.
Ideally £900 but £950 seems to be more realistic. As I said in previous post, lets drop the keyboard, mouse and HDD to see what we can come up with. He already has a kb mouse and 250GB SATA HDD for storage. Also he has a 120GB SSD which we are going to use.
His current PSU is a Combatpower 650W with something like 18A on the 12v (likely dual) rail. So reusing that is a big no-no!
