- 21 Jul 2005
- Officially least sunny location -Ronskistats
Stick to that mantra regulus it works. As for the clowns steer clear of them and their goofy negativity.
It's not struggling with anything so far......
You don't use a discrete card? That must have been one heck of a driver update for the HD3000.
I suggest you open your eyes a little wider![]()
I suggest you lie down otherwise you are going to explode with stress before the start of a new week.
Wow. You're so hard.
P.S.
You're not winding me up. You're just making yourself look like a moron who boasts about running uber hardware to try and deflect the fact that he's wrong. And it's not just me who sees it, the whole world does. It's the fact that you can't see it that makes it all the more hilarious.
Just had a long Crysis 3 session. CPU never got above 32c or were stressed in anyway. I got it back running on stock. No determinable difference. Clocked it to 4.5. No major difference. However, when I started clocking my GPU, frame rates crept up.
Not a bad little chip for the 100 measly bucks I paid for it![]()
Crysis 3 does not use all of a CPU on certain levels. This is why there was so much confusion with it at launch, with several levels preferring Intel quad core chips, then, 8 core AMDs. The train depot level seems to stress the GPU far more than the CPU.
If you want to see your PC poo its guts through its mouth then go to the swamp level or Welcome to he jungle. Both will put a serious load over all 8 cores![]()
Never had any issues on 'Welcome to the Jungle'. And I assume the Swamp Level is the one in China Town?
The only time I ever noticed a dropped in performance is during massive explosions, and then only into the low-mid 30s. I'm actually amazed Crysis 3 runs so well on a 7950. And here I was ready to buy a Titan to play this game maxed out.
Turn on 8xmsaa, watch your rig die.
