- 22 Sep 2005
- Manchester
Hey guys,
I've just come off a bit of a mad diet, and I'm now eating healthy and cooking more... with this comes my need to acquire more mad gadgets. This time it's an Indian tandoor oven!
I love Indian takeaways; which is mostly the reason I had to go on a diet... I could eat tandoori chicken tikka all day long, which is generally not that bad for you... but when it comes with korma sauce, poppadoms, naan, and other greasy bits and bobs it starts to loose it's once moderately healthy status. There's another BBQ takeaway which we also used to frequent - very spicy chicken flame grilled chicken breast, but served with bread, chips and coke... so again - same problem; nice healthy chicken - with all of the bad-for-you extras.
I've tried to make this kind of thing myself before in a pan and it doesn't work so I thought I'd see how much of a effective tandoor I could make in my garden for as little money as possible. I saw this video on YouTube
and I thought the design was quite cute; although it looked a little small the general idea was pretty good.
I have made something along these lines and have just had my first chicken kebabs from it - great success!
the tandoor
kebabs!
testing one piece
You will need:
1* 43cm terracotta flower pot (£9.99)
2* 30cm terracotta flower pot (£4.49)
1* 15cm terracotta flower pot (£0.79)
1* set of terracotta pot stands(£1.99)
1 bag of all purpose 10mm gravel (£2.49)
Everything was bought from Homebase. I was shocked that terracotta pots would be so cheap; and that I could get it all in one place. I used gravel instead of vermiculite; it's one of those things that everyone on the internet says you can just get from any old DIY store. you cant.
I've had this problem before trying to find it and had to use very expensive round balls of vermiculite in a tropical frog vivarium once and it was very expensive. I guess it's lighter and a better insulator - but the gravel does seem to be working fine for now and was dirt cheap.
Method:
1. saw the bottom off a 30cm pot and keep the base to use as a lid. set to one side.
2. saw the rim off a 15cm pot and snap it into thirds, set aside.
3: arrange the pot stands int he bottom of a 43cm pot and make a circle out of the thirs fo the pot rim that you snapped; making the pit stands fill in the gaps. This is to form a barrier against the gravel that you will pour in later on.
4. place an untouched 30cm pot into the 43cm pot and rest it on the pot stands.
5. place the sawn-off 30cm pot rim-down onto the rim of the other 30cm pot to form the inside of the oven.
6. fill the outside with Vermiculite (or gravel, like I did)
7. make a grill to suspend the coals on and place it int he bottom of the oven.
Video Method:
Sorry, this video is crap... I didn't want to spend any more time than I did making it!
Observations:
1.
Things at the bottom of the skewer burn. A big bit of lemon prevented this only a little bit; but really I need to get the meat higher up the skewer, for this I need longer ones (these were a quick grab from test and are probably fine for bbq but not for tandoor cooking)
I've seen some thick, long square skewers on ebay which I might buy this week - it certainly needs them! and then I will be able to do seekh kebabs also.
2. lumpwood charcoal; although messy and smokey does seem to be the better choice over briquettes. I used a combination of both though.
3. don't rest the pointy end on your oven-mitted hand otherwise it will instantly burn a hole right through the glove and make a considerable burnt hole in your finger.
pros:
+ very cheap
+ fool proof
+ gets very hot and lasts for ages
+ has not cracked yet - not bothered if it does!
cons
- top could do with insulating
- quite heavy
- requires more gadgets (kebab skewers)
So show me the food!
Well, you see... what happened was a massive technology fail right at the end; on top of hunger turning to anger. and what I did was have a massive huff, and ate my chicken in a sulk, watching telly. I put the chicken in a pitta which I left in the tandoor and burned, then dropped on the floor. it had salad and a tiny amount of mayo. it was vey nice, but the next step is finding the recipe that my local Indian takeaways use for the marinade.
if anyone knows the answer please tell me! there are too many recipes online that are simply nowhere near the real thing. I was considering just asking my local what they use to be honest - but that means going in and ordering some of their chicken plus a bucket of grease to wash it down.
your turn!
the tandoor
kebabs!
testing one piece
You will need:
Method:
Video Method:
Observations:
1.
pros:
+ very cheap
+ fool proof
cons
- quite heavy
your turn!
