- 26 Nov 2009
I installed windows after formatting the whole 128GB and have used about 40GB. Samsung Magician says there is insufficient free space to set up Over Provisiong? Can I do without it?
Just don't fill it up, leave about 10-15% free. This effectively what OP does.
Overprovisioning is utterly pointless, and I wish reviewers would stop writing about it. The ONLY time it comes into play, is if the drive is completely full AND you are thrashing the living daylights out of it, simultaneously. If both those conditions aren't true AT THE SAME TIME, then overprovisioning provides no benefit. And you lose part of your drive -- I just don't get why these "tech tweaks" gain a life of their own.
=)Ouch. Say what you mean why don't you?
That so true tho, plus most people know that they must not fill up a ssd totally, so yeah "Over Provisioning" is totally pointless, unless you know nothing about SSD's.
Well I know about SSD's and I O/P my 840 pro. Helps with keeping performance up.
Over provisioning prevents the user filling up their SSD (and therefore possibly reducing performance and the life of the SSD).
No harm in enabling it if you aren't going to be filling your SSD fairly close to capacity. It's a "safety net".
But whats the point is enabling it, if you know that your not going to be filling up the SSD![]()
Its like having 16 gigs of RAM when you don't use it in it.
What Im saying. If you know you must not fill a SSD totally up, then why bother using the Over Provisioning.
But if your a complete beginner with computers and stuff use over provisioning,, but then again if you dont know much about computers, you prob wont install the samsung software anyway, so the OP is kind of floored and pointless if you look at it that way, as you need the software installed to use the OP.
Er no. You can just make the partition smaller in disk manager
