Have I toasted my CPU? :(
24 Dec 2004
Hello all,
I have been very happily assembling my new build, i7 4770 on a Gigabyte Sniper motherboard and just when I wanted to tidy up a bit the case (remove old DVDs and stuff) I have somehow managed to get the main cable from the PSU to block the CPU fan. I noticed it after a few minutes as the PC did not post. I did not hear the starting sound either but did not pay attention.
I amended the situation, restarted the PC but after several attempts no joy. The Debug LED goes up to 99 and then settles at 72 or something.
I have the feeling that a new CPU might be on its way.
What do you guys think? I cannot believe that I have done something so stupid that it could go to the Guinness Book of records. :mad:
Thank you in advance for your advice!
Cheers,
Jordan
EDIT: Would a reset help? Or should I clear the CMOS? Or Both?
Phew!!!!!!
After 20 agonising minutes envisaging a loss of another couple of hundred quid it POSTED!
I guess I must have cleared the CMOS, some thermal defence mechanism had prevented it from starting.
I would still like to hear what usually happens inn such situations, not that I am planning a repeat :).
Cheers,
Jordan
Pleased to hear you got it working mate, never nice to hear forum members having components die on them, just glad you brought yours back from the dead :D
Lucky for you the thermal cut-out was enabled in bios, I always check this is on & also check cpu fan settings.
