Are PSU's without a 120mm fan still made?
26 May 2009
As title, looking for a decent PSU with front and/or rear 80mm fan, I know you can get low wattage brand X ones but it needs to be reliable, replacing a 660W Enermax unit form 2005.
Any ideas?
Why do you need one like this?
Not taking a dig, just asking...
You can get fanless ones too, as im sure you know..
I think some hig-end antecs may use back fans. . Ill take a look for you.
The case has a support bracket under the PSU which would completely block a 120mm fan.
The previous PSU was a 660W ENERMAX EG851AX, which has front and rear 80mm temperature controlled fans, sadly after running 24/7 for nine years it's soul has departed.
