Weird screen flickering in LoL
16 Nov 2011
Nottingham
Hi
I haven't been having this problem for long, maybe a patch? but anyway, I'm getting screen flickers during random intervals whilst in game; they appear and disappear too quickly for me to tell what's happening or what they look like, but they're annoying. I haven't had this issue in any other game. I have latest drivers for my R9 280X and the card is only ~1 month old.
Thanks
(wasn't sure which section to put this in)
Tearing? Does it happen if v-sync is enabled.
Nah it's not tearing, don't use v-sync either.
I'm not really sure about the lingo for it so the explanation might seem a little abstract. Not sure if it's a texture error or what since it happens too fast for me to tell what it is, but it's definitely noticeable .
Had a similar problem by the sounds of it, well mine was also hard to explain? Do certain graphics not look right either? Big one for me was SHaco's jitbs. They were just some big hideous blue square!
If this sounds familiar I deleted gpu drivers and re-installed them, but not the latest beta ones. Seemed to do the trick.
I have r9 280x
Uninstall LoL and install Dota 2. Sorted :D
On a serious note have you tried rolling back your GPU drivers or completing a "clean" install of them?
I've found if you alt-tab during the loading screen sometimes it can cause textures to get swapped/corrupted.
I get it all the time random flashes of texture on the screen, also my pc decides to freeze for a split second soon as first blood is called :|
Hi
Thanks
Sounds like the same problem with 7900 series had, they released a post a ages saying there was an issue. The flickering is basicly a multi coloured layout on the screen really fast
Basicly this but its super fast and the colours can be different
Yes, it could be this, but only one of them will appear at a time, not all at once.
