Gigabyte GeForce GTX 780Ti WindForce 3x OC 3072MB GDDR5 PCI-Express Graphics Card (GV-N78TOC-3GD) @ £520.00 inc VAT
GIGABYTE, the world leader in high-performance gaming hardware and system, is pleased to announce the latest graphics card, GeForce GTX 780 Ti Overclock Edition (GV-N78TOC-3GD). With 25% plus CUDA cores than GTX 780, the most powerful thermal design in the world and exciting new technologies, GV-N78TOC-3GD is going to bring all the gamers an extremely gaming experience to a whole new level. The exclusive WINDFORCE 3X cooling design guarantees you to dissipate 450 watt heat out. Enjoy your game play with a stunningly beautiful and quiet design is no longer a dream. It also supports OC GURU II and GPU Boost 2.0 for maximum clock speeds. GV-N78TOC-3GD features PhysX® and TXAA™ technologies for smooth, sharp graphics, and GeForce ShadowPlay™ to capture all your greatest gaming moments automatically. Whether you play on 4K monitors at extreme settings, GV-N78TOC-3GD can provide the horsepower to drive all your next-gen gaming visual experiences.
GIGABYTE innovatively presents WINDFORCE 3X 2-SLOT cooling system, thinner and cooler! The thermal structure contains three ultra quiet PWM fans, an only 2-slot height heat sink with exclusive "Triangle Cool" Technology, two 8mm and four 6mm cooper heat pipes and a high-performance RAM heatsink.
The innovative thermal design guarantees the heat dissipation capability to over 450watt. The cooling performance is 14% significantly better than stock fan! WINDFORCE 3X 450W cooling system not only provides an effective heat dissipation capacity, but also gained a higher performance with lower GPU temperature through the GPU Boost 2.0 technology.
According to the latest NVIDIA® technology, GPU BOOST 2.0, GV-N78TOC-3GD provides gamers an unlimited overclocking capability. By using GIGABYTE exclusive OC GURU II, gamers can monitor and adjust all important settings such as GPU clock, memory clock, fan speed, voltage, power target, OSD and online support. With the upgrade and easy-to-control user interface, GIGABYTE OC GURU II becomes the best mate while using GV-N78TOC-3GD.
Specification
GeForce GTX 780Ti
- GPU: GeForce GTX 780Ti (GK110)
- Core Base Clock: 1020MHz
- Core Boost Clock: 1085MHz
- Memory Clock: 7000MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Features
- MAX your overclocks with NVIDIA's Power Balancing
- A WHOPPING 2880 CUDA Cores (Fully enabled GK110)
- GPU Boost 2.0 Technology
- TITAN cooling system
Only £520.00 inc VAT.
ORDER NOW
_____
MSI Radeon R9 280X Gaming Edition LE 3072MB GDDR5 PCI-Express Graphics Card @ £221.99 inc VAT
R9 280X GAMING LE 3G OVERVIEW
R9 Series Graphics
The AMD Radeon™ R9 280X graphics processor harnesses visionary GCN Architecture. This GPU is primed to enable astonishing performance and breathtaking image quality, making it a top choice for gamers who expect the best.
LET THE GAMES BEGIN
A graphics card is the single most important element for more FPS. As gamers, we understand that not just any graphics card "will do". That's why we bring you the best of the best. We don't want to bug you with noise and heat, but we DO want to give you more performance. With MSI GAMING series graphics cards you get just that.
MILITARY CLASS 4 COMPONENTS
Military Class 4 is the next step in high quality components. The Hi-c CAPs, Super Ferrite Chokes and Dark CAPs will make sure that your PC runs more stable under extreme gaming conditions.
ADVANCED TWIN FROZR IV
MSI's Twin Frozr has been the industry defining graphics card cooler. The first Twin Frozr kicked off the dual-fan trend and today MSI stays true to its dual-fan dual-slot design where others have to resort to less effective means.
AFTERBURNER
MSI Afterburner has quickly become the favorite overclocking software for media, overclockers and end-users. Because of its simple interface, it's easy to learn, but it packs a lot of powerful features like an integrated benchmark utility called Kombustor that can check your system performance in benchmarking mode, or run as a stability test.
GAMING APP
EASY TUNE, EASY PLAY - OC Mode, Gaming Mode and Silent Mode available at a click of a button. You decide!
PREDATOR
A built-in screen and video capturing tool named Predator which captures your screen as still images or videos with the push of a button and allows you to capture and record your coolest, goofiest and most awesome gaming moments on your PC!
Ultra Resolution Gaming
Leave HD in the dust by gaming on displays much, much larger. Whether using a 4k monitor or combining multiple HD monitors, you’ll get an expansive experience that’s truly out of sight.
GCN Architecture
Primed to enable astonishing performance and breathtaking image quality, making it a top choice for gamers who expect the best.
AMD CrossFire™ Technology
With outstanding performance scaling, a system equipped with AMD CrossFire™ technology keeps you fragging while everyone else is reaching for an upgrade.
AMD Eyefinity Technology
Enjoy the ultimate immersive gaming experience with innovative “wrap around” multidisplay capabilities.
AMD HD3D Technology
Play 3D games, watch Blu-ray 3D videos, and edit 3D photos on your 3D monitor, TV or projector.
AMD App Acceleration
Improve performance of everyday tasks such as Web browsing, office applications and video rendering.
AMD PowerTune Technology
Enables intelligent power monitoring to enable higher clock speeds and better performance in your favorite games.
AMD ZeroCore Technology
Allows your AMD Radeon™ GPU to consume virtually no power when in idle state.
Specifications
Interface:
PCI-e 3.0 (backwards compatible with 2.0)
Core Speed:
950MHz (1010MHz Boost Speed)
Memory Buffer:
3GB GDDR5
Memory Speed:
6000MHz
Memory Interface:
384-bit
Connectivity:
1x DVI, 1x HDMI, 2x Mini-DP
Stream Processors:
2048
HDCP Support:
Yes
Max Resolution:
4096x2160
DirectX Support:
DirectX 11.2
CrossFire:
Yes
Monitor Support:
Up to 4 displays
Power:
1x 6-Pin + 1x 8-Pin (250W TDP)
Dimensions:
269 x 128 x 34 mm
Only £221.99 inc VAT.
ORDER NOW
Specification
GeForce GTX 780Ti
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Features
ORDER NOW
_____
R9 Series Graphics
LET THE GAMES BEGIN
AFTERBURNER
GAMING APP
PREDATOR
GCN Architecture
AMD HD3D Technology
Specifications
Interface:
Core Speed:
Memory Buffer:
3GB GDDR5
Memory Speed:
6000MHz
Memory Interface:
384-bit
Connectivity:
Stream Processors:
2048
HDCP Support:
Yes
Max Resolution:
4096x2160
DirectX Support:
DirectX 11.2
CrossFire:
Yes
Monitor Support:
Up to 4 displays
Power:
Dimensions:
269 x 128 x 34 mm
ORDER NOW
