£1400 budget build including monitor?
20 Jan 2014
Hi guys,
First time poster here, just wondering if you guys could spec me a £1400 build including monitor? will mainly be used for gaming, design and streaming. relatively new to this so dont want to embarass myself by posting my own build. let me know what you guys think :) oh and if possible can the monitor be 24" too.
thanks
Ross
Yes, it would be fine.
I would however lean towards Dooms spec, the extra grunt from the 290x would be quite something, especially when Mantle is released.
@DOOM, I did try to keep into £1400 as close as I could :)
Nice specs guys. I'd just change the LED lighting to white, and find some suitable Avexir Red memory. Otherwise the whole thing looks too red and you don't really see how well it matches. Could even go for a NZXT Hue to allow all sorts of lighting options and effects, although you'd have to store the module somewhere inside the interior (as it doesn't have 5.25" bays). That shouldn't be too much of a problem. Loads of room.
Yeah love the monitor, looks great. Thanks for your help guys, really appreciate it.
one last question, whats the best keyboard and mouse I get get for £100 (together not individually)
£1500 spec and I wasn't invited :eek:
Oh well I'm massively over as normal :(
YOUR BASKET
1 x OcUK Geforce GTX 780 3072MB GDDR5 PCI-Express Graphics Card £359.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £245.99
1 x NZXT Hale Power 90+ 850W '80 Plus Gold' Modular Power Supply £129.95
1 x Iiyama Prolite E2483HS-B1 24" Widescreen LED Monitor - Black £129.95
1 x Gigabyte G1.Sniper Z87 Intel Z87 (Socket 1150) DDR3 ATX Motherboard £119.99
1 x NZXT H440 Mid Tower Case - White £94.99
1 x Antec Kúhler H2O 1220 Series 4 High Performance Liquid CPU Cooler £81.60
2 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £79.99 (£159.98)
1 x Avexir Venom Series 8GB (2x4GB) DDR3 PC3-17200C9 2133MHz Dual Channel Memory Kit (AVD3U21330904G-2CIG) - Green Light £79.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £59.99
1 x Samsung SE-S208DB/TSBS External Slimline 8x DVD-RW (TV Connect) - Black £21.98
1 x BitFenix Alchemy Premium Modding LED Strip - Connect White 30cm £16.79
6 x Alpenföhn 120mm Wing Boost Plus PWM Fan - Shamrock Edition £12.95 (£77.70)
1 x BitFenix Alchemy 24pin ATX extension 30cm - Green £8.99
1 x BitFenix Alchemy 8pin PCI-E extension 45cm - Green £6.98
1 x BitFenix Alchemy 6pin PCI-E extension 45cm - Green £6.49
1 x BitFenix Alchemy 8pin EPS extension 45cm - Green £5.99
2 x BitFenix Alchemy SATA 6GB/s braided cable 30cm - Green £5.99 (£11.98)
1 x BitFenix Alchemy Internal Audio Extension Adaptor 30cm - Green £4.49
Total : £1,654.33 (includes shipping : £25.45).
YOUR BASKET
Only ~£150 over budget, nowhere near your usual standard :p
