Steelseries Siberia V2 and the Plantronics GameCom might be worth a look.
They are shockingly bad and poor build quality WHEN COMPARED to the Qpad QH 85 which cost 75, and I owned both the headsets you mentioned.
To the OP, get the QPad QH 85 and you will be amazed, when it comes to gaming, the headset can be compared to headphones that cost 2-4 times as much!
Damn. My bad then, just seen them talked about a lot as far as 'budget' headsets are confirmed; haven't tried either myself, I've just had A40s for the past 3 years..![]()
I tend to be up down from pc in a evening, don't want to have to take a headset off and unclip a mic all the time to be honest. So a headset with mic integrated for definite
I got the Razer Kraken Pro recently, they're good. Good sound quality, they feel durable and the mic hides away neatly in the left earcup. Comfortable aswell even for hours on end.
There is a black version if the bright green doesn't appeal![]()
ASUS Xonar DG, Creative Aurvana Live and a Speedlink SPES clip-on mic.
All for £80 and far superior.
