PSU for GTX 480
Caporegime
17 Jul 2010
Must have 6&8 pin graphics connectors, other than that a couple of Molex and SATA will do. Hopefully around £50 or so. I take it Modular isn't really doable at this price range?
This caught my eye: http://www.overclockers.co.uk/showproduct.php?prodid=CA-008-EA&groupid=701&catid=123&subcat=2463
And this one: http://www.overclockers.co.uk/showproduct.php?prodid=CA-075-BQ&groupid=701&catid=123&subcat=2463
Also: http://www.overclockers.co.uk/showproduct.php?prodid=CA-208-AN&groupid=701&catid=123&subcat=2463
Any other suggestions?
It's a pretty low spec system. Two Molex powered Optical drives, a SATA mechanical hard disk and a S775 e7400 CPU with 2gb ram. The 480 was a free upgrade from a 9600GT for my sons machine.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-070-AK
http://www.overclockers.co.uk/showproduct.php?prodid=CA-115-CS
http://www.overclockers.co.uk/showproduct.php?prodid=CA-016-XG
http://www.overclockers.co.uk/showproduct.php?prodid=CA-016-SF
All under £50 and will run the system NO problem
the modular CX @ £37 will be fine
the superflower will be fine, the maximum that gfx card will draw is 42A and the 12v rail on the superflower is 45.5A so it will be fine unless he is overclocking like crazy on it ,
the other psus are all tat except maybe the akasa 650w which does 49A but only 585w which is fine for him but i would definately go for the superflower!
That is awful advice. The CX430M is a budget psu with only 32A/386w on the 12v rail and i doubt very much that it would run a GTX480 for very long before failing. That's even if it would run it at all.
