£1,500 Gaming PC Build
Are there any cheaper cases that the H110 will fit inside?
Edit: Can you maybe spec a blue themed variant of what you posted earlier, Doomed? I think I want to go with the Corsair Vengeance C70 and seeing as it has a blue tint, orange wouldn't go too well :p
Sorry the spec took a while: :)
YOUR BASKET
1 x Gigabyte Radeon R9 290 OC WindForce 4096MB GDDR5 PCI-Express Graphics Card (GV-R929OC-4GD) £389.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - OEM £249.95
1 x Be Quiet Power Zone 850W '80 Plus Bronze' Fully Modular Power Supply £119.99
1 x Gigabyte Z87X-D3H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £119.99
1 x OcUK Tech Labs Fathom All in One Custom Cooler 240mm £112.97
1 x Mayhems Pastel - Blue Berry Coolant 1L £14.99
1 x XSPC EX240 120mm Radiator - Black £37.99
1 x Corsair Vengeance C70 Midi Tower Gaming Case - GunMetal Black £99.95
1 x Kingston HyperX Predator 8GB (2x4GB) PC3-19200C11 2400MHz Dual Channel Memory Kit (KHX24C11T2K2/8X) £79.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £76.99
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £71.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £65.99
1 x Corsair AF120 Quiet Edition Low Noise High Airflow - Dual Pack (CO-9050002-WW) £19.99
1 x Corsair AF120 Performance Series Low Noise High Airflow - Single Pack (CO-9050003-WW) £13.99
1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £11.99
1 x BitFenix Alchemy 24pin ATX extension 30cm - Blue £8.99
1 x BitFenix Alchemy 8pin PCI-E extension 45cm - Blue £6.98
1 x BitFenix Alchemy 6pin PCI-E extension 45cm - Blue £6.49
1 x BitFenix Alchemy 8pin EPS extension 45cm - Blue £5.99
1 x BitFenix Alchemy Molex to 3pin x3 Fan adaptor 7V 20cm - Blue £4.99
Total : £1,544.30 (includes shipping : £20.10).
I picked the RAM because of this and this alone:
CAUTION: Users may experience extreme motion sickness and/or complete disorientation from the extreme speeds typically reached with HyperX® Predator. It is not intended for small children, the faint-at-heart, people with a lot of time to complete a creative project or anyone who settles for less. Featuring frequencies up to 2800MHz and a new heat spreader for greater heat dissipation, it’s Intel XMP ready, compatible with all popular brands of motherboards and backed by legendary Kingston® reliability. We might even recommend a helmet.
Just so you know, the cooler is OCUK's version of a H100i using a coolermaster pump/block combo and real custom watercooling rad/tubing/fitting put together by Rich's steady hand.. :) It should outperform the h100i considerably.
Sorry for bumping this but thought I should give you guys an update on how it's going. Here's the spec I went with:
Got half of it already, the rest will be arriving some time next week. Only trouble is I'm having to get it delivered to work but I don't drive - can't exactly hop on a bus carrying this stuff :P
TAXI! :D
True but the cost would be expensive enough even if we hit every green light on the way home, thank you very much rush hour :mad:
You guys are killing me :( I've got all the parts that I need apart from the case which comes tomorrow (hopefully!). It's pure torture looking at all this powerful hardware and then at what I'm using to type this message..
