How often do you leave your electric heaters on? When I first moved into my house I had a bit of damp (caused by condensation) under my stairs, I had two electric heaters on 24/7 for about two months - my electric bill tripled.
That bill sounds about right to me. I used 920Kwh last quarter which works out as 1840kwh for 6 months.
Granted, im living in Darwin, but replace central heating with aircon (in bedrooms only), solar hot water. I have a laptop thats left on 24/7 as well as a NAS drive.
Im in a 3 bedroom bungalow but most of the time, im the only occupant.
1 bed flat, everything is electric. £27 a month.
These sort of usage stats blow my mindp). I actually have an energy monitor connected to my incomer, my house base loads at around 500W of draw when everything is switched off bar "services". "Services" being 24/7 items, off the top of my head in my case being items such as routers, access points (cellular/wifi), switches, fridges/coolers, freezers, file servers, printers, AV devices, car battery conditioners.
This is £50/pcm absolute minimum for base services. I imagine most sizable houses as opposed to flats probably have similar running as a base load although if i lived in a flat i cant imagine that it would differ greatly. I would guess at a usual house using £100-£150pcm in electricity all told ignoring heating costs which would usually be a different fuel.
The answer to the thread is that everyone uses vastly differing amounts and a sensible bill for one person is not sensible for another. There is no way even turning my house to complete "idle" mode all month with us on holiday that it would use as low as £27 worth of units.
That's about what I used to use in my old flat on a card meter (£25-£45 P/M) using exactly the same electricals that I have in my new flat... My old flat / last winter was also a lot colder than this year. Since I have moved to direct debit billing my bills have almost doubled, all these phantom charges, 2 tier pricing, late charges (although it took them 5 months to setup my account after multiple emails), it is a rip off. I am not sure that it is legal for them to charge me the 2 tier pricing in 2014 because I read that this has been banned as it is unfair to people with low electricity usage, for example "cost of first 203 KW/H 21.8p (!) - cost of next 1058 KW/H 13.6p". Only way I will know is to get a plug in meter and measure my stuff, but as it was around half this with a card meter in my old flat I am not pleased about it.
Well from now on I am taking meter readings every 2 weeks, might also switch to a card meter, I am not going to pay what they have asked until I have measured all my stuff and confirmed that it is physically possible that I could have used 760w, 16 hours a day for 103 days in summer with no heating! Does not sound right to me! It seems that unless you take regular meter readings and know your exact usage they will try and charge you for as much BS as possible!
You are unsure if it is legal?
What?
You're either on a tariff or you are not.
What tariff are you on?
What was your starting reading, what is your reading now?
What is your unit cost for the sections of your billing period?
When they setup the account for you (after these months of emailing, when a phone call might have sorted it) what account did you actually sign up to?
