** Gigabyte P27K Laptop Review **
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
buy now £999.95
Introduction
Well what is a laptop? Most people generally think that laptops are either for sales people, who are on the road visiting customers or for families who want a lost cost, space saving computer to browse the Internet, read emails and maybe play the odd Facebook game. Well over the past few years I feel that this is a changing trend. All of the above is moving away from a typical laptop in favour for the tablet are taking over that role. So where does that leave Laptops? Well Gigabyte have answered that question with the P27K Laptop, with it being marketing it as a “Gaming Laptop”. I’m here to decide whether it can claim that title.
Design
The P27K is offered in two flavours; all black, or black with an orange lid. The model I’m testing is the all black edition. The first thing you notice with the design is the large nature of the unit, this is down to boasting a 17.3”, 1080p screen. The rear of the screen has a somewhat robust/robotic design with its angular shaping, this gives it the feel of being gamer orientated. Upon opening the lid you instantly see a nice looking full size keyboard with a full number pad. Again the angular theme is portrayed here, between the top of the keyboard and the screen have the same style which adds to the whole design. The actual build quality is spot on too, the plastic used is of very high quality while a great matte finish and whole unit screams out as being expensive. The screen hinge is very robust feeling and I have no concerns that even with a number of years usage this will stand the test of time. After a hour or so usage I did find one thing that wasn’t designed too well, the front of the laptop has a very sharp front where your wrists rest when typing, this can become quite unconfortable after prolonged usage. Gigabyte could have rounded it off a little too rough the pressure put on your wrists.
Specification
This is the part that really did appeal to me when I was asked to review the unit. An i7 CPU with a clock speed of 2.4 GHz that can boost up to 3.4 GHz and a 128GB mSATA SSD and a 1TB Storage drive. The biggest appeal for me was the GTX765M dedicated GPU with 2 GB of GDDR5 memory to boot. The rest of the spec is typical of most modern laptops; wifi with 802.11b/g/n, Bluetooth, a 2 Megapixel camera and a DVD-RW or BluRay Combo drive depending on the spec you choose. The OS is the latest Windows 8 and is pre-installed for you. Finally the connectivity options built in are very good, with two USB3.0 ports, an eSATA/USB3.0 shared port, a single USB2.0 port, HDMI and D-Sub outputs, a RJ45 Network port, two audio ports for a mic-in and earphone –out, a 9 in 1 card reader and S/P DIF Out.
Display
This is a major bone of contention for me with many laptops is poor resolution screens, as during my working day, the work laptop I use is only a 1366 x 768 screen. This is not ideal for me and it is rather frustrating especially when working with software such as Excel which benefits highly larger resolutions. How did we cope with the old VGA resolution of 640 x 480 many years ago I do not know. Anyway back onto the Gigabyte screen, this offers a massive 1920 x 1080 resolution. I would personally have a 13” screen with a 1080p panel that a 17” screen with a 768p screen. The clarity of the Gigabyte screen is wonderful due to being full IPS as opposed to many inferior laptops that only offer a TN panel, and the wonderful anti-glare matte finish compliments the same matte finish on the rest of the device.
Software
For me this is one of the biggest annoyances when purchasing a pre-build laptop or desktop system from a large manufacturer. Personally my own desktop PC is a self-build PC which of course I install a clean OS on. But manufacturers love to create their own software and force it down the throats of unsuspecting customers. Gigabyte is no exception to this with something called Smart Switch this is a totally useless piece of software which is pinned to your taskbar and offers nothing that cannot be accessed easily from Windows anyway. This is just bloatware. Luckily Gigabyte made is easy to remove this software. Gigabyte also decided it would be a great idea to have CyberLink Power DVD 10 pre-installed on the laptop. Upon opening this it gave me the option to upgrade to a full-edition with various “benefits”. VLC Player is all I need for DVD or any other video format playback, so again this software was promptly removed. I assume Gigabyte get some kind of kickback from the software house that produces PowerDVD. Other than that the rest of the software was just the standard windows software with all the correct hardware driver installation setup.
Gaming
As already stated this laptop is equipped with a high end laptop GPU, the GTX 765M with 2GB of GDDR5 RAM this boasts a clock speed of 900 MHz. The best way to test the machine is by doing what I enjoy most……playing games!
I fired up Borderlands 2 and after a quick play in the options menu I had the GFX settings setup with the following: 1920 x 1080, Field of View = 110, Anisotrphic Filtering = 4x, Bullet Decals = high, Foliage Distance = Far, Texture Quality = High, Game Detail = High, Ambient Occlusion = On, Depth of Field = On, FXAA = On, View Distance = Ultra High, Physc Effects = Low, Texture Fade = On. I jumped straight into the game and play for about 30 minutes. Fraps was installed and the game gave an average of about 45-50FPS when roaming in large open zones. In heavy battles with a number of mobs with grenade explosions causing debris to be rendered on screen heavily the FPS did drop a little but it still maintained 30+ FPS at all times. I did manage to get the odd slow down below 30 FPS but this was rare and only lasted for a second and then it rose back above 30 FPS, this was during the time I was in a vehicle and enabled turbo boost causing a lot of fast movement. Overall Borderlands 2 was perfectly playable at max settings. I tested it at medium settings on all the options and I got a solid 60FPS for everything with the exception of turbo vehicle driving but that remained a steady 40-45FPS minimum.
Battlefield 3
Battlefield 3, is one of the most hardware intense games to be released (and now Battlefield 4). I will be completely honest, at 1080p the running the game on high settings was not great, the game ran at about 25 FPS, which is not nearly high enough for a “gaming laptop”. Fast online FPS games require a decent FPS (40+) otherwise you get your ass handed to you in game, no matter how good you are. Changing the settings to medium and reducing the AA down to low did massively help the FPS counter but my personal feeling is that if I’m spending over £1000 on a gaming machine, whether it be a laptop or desktop machine should be able to cope with the higher graphics settings.
Audio
The speakers in the laptop are decent enough for a laptop, they are far better than the majority of laptops, generally laptops which are not intended as a gaming machine have very poor speakers built in. However, I have previously experienced a gaming laptop from another manufacturer and they are much better than these speakers. The audio is loud and clear, but does lack that clarity and punch. The only defense I can come up with for Gigabyte is that many gamers do tend to use headsets, so they decided to go mid-range with the audio setup here.
Keyboard
The laptop keyboard is great, it has low profile buttons and the overall feel of the design and size is great for gaming. I feel that the 17” screen works in tandem to ensure that the keyboard is of a decent size. The only let down as already stated is that the front edge of the laptop makes prolonged keyboard usage quite uncomfortable.
None Gaming Usage
When browsing the web, writing documents etc (I using the Laptop to write this very review) the hardware is brilliant, it’s fast, responsive and feels as quick as any high end desktop machine. This boils down to two main reasons, firstly the powerful hyper-threaded i7 processor combined with the 1600mHz RAM and secondly the mSATA SSD. Combined these 3 components make for an extremely enjoyable computing experience.
Battery Life
The life of the battery when gaming is dire, it lasted less than an hour when playing any game I tested, so you really need to have a main power source to game on it at all. When not gaming, in windows browsing the web or with Office open then the battery lasts quite a bit longer, around 4 hours with the screen brightness on a high setting, which isn’t bad at all. Should be able to get 6-7 hours out of it with a lower screen brightness. I do work on the road myself, and I have a small Samsung 15” laptop which isn’t intended for gaming, and I can get a full 8 hour days’ worth of use from that without a recharge, the P27K would certainly struggle to do that.
Conclusion
If you are looking for a very accomplished gaming laptop for you to use at home then this machine ticks all the boxes in my opinion. If you are looking for a truly portable laptop with the battery being the main source of power most of the time I would suggest maybe finding a product which is less of a power drain. The price online is around the £1000-£1100 price depending where you shop, so it is certainly not the cheapest of gaming laptops, but is one of the best gaming laptops on the market.
Screen Quality – 9/10
Sound Quality – 5/10
Processing Speed – 8/10
Connectivity – 8/10
Features – 7/10
Build Quality – 7/10
Gaming Quality – 7/10
Value for Money - 7/10
Overall Verdict – 7/10
Based on the laptop being under £1K now (when I wrote it your price was £1100)
So now value for money 8/10
I'm just linked your question to Gibbo to him via a facebook message, so he should hopefully answer you soon. (He is showing as offline though at the moment)
Shame new laptops are not all shipping with Wireless 802.11ac cards.
True....much as I really like my P35k, it is disappointing that it ships with a pretty mediocre Intel wireless card. Not particularly easy to get at, either :(
Shame, as my shiny RT-AC68U is looking for a like-minded soul...at the moment, only my phone links on ac!
