Hi All
I need bit of a help with my recent project. My plan is to build pc inside desk drawer (BESTÅ BURS from Ikea), as you can see on the pictures. Drawer dimensions are 71cm x31cmx8.5cm walls are made from MDF same with bottom part which will be replaced with 3mm aluminum.
Components I will use are
Standard HDD
ATX Asus p5q Deluxe Mob
GTX 285 (not oc)
Hiper 750W PSU (leave it alone, I like it and it works for 7 years now)
Intel Q6600 (not oc)
Arctic Cooling Freezer Xtreme ( will need to be replaced with low profile)
PSU is slightly higher then the drawer so I will cut out hole and lower it slightly with fan being outside, same with gpu
I think there is 5 mm gap between top and drawer
Looking at the pictures do you think I will have any problems in terms of cooling or noise, having in mind top will be covered so almost no ventilation except what you see?
The fans I can use are 60mm, if I use 80mm I will have to install support rods to strengthen the construction of the walls. Option is to place addition fan on the bottom between mop and gpu.
Are their any risks of having gpu in that position?
And what fans and cpu cooler do you recommend? I have only 8.5 high having in mind mob will be raised few mm therefore I’m looking at 8cm between processor and top
Do you think this will work with only 2 fans or will I need more?
If this work and temps are decent I’m planning to upgrade To
M-Atx Intel Core i3-4130 and R9 270x or A8 7600 65W
My first plan was to get fx 6300, but it’s running at much higher Thermal Power
What are the cons and pros ?
Thanks
Standard HDD
GTX 285 (not oc)
Thanks
 but look at this
