Is it cheap windows that can cause this the temperature bridging thing?
I hope so! That's what I'm planning to do (I have trickle vents on order). I believe it's a case of drilling a number of holes through the plastic of the frames of the opening windows (on either side of the frame) and then fitting the vent over the top. Will report back my findings as i'll probably do this next weekend if the vents are delivered.
We have the same issue in our smallest bedroom (boxroom) , the condensation in there is horrific, running down the windows, running down the walls, furniture/bedding/clothing which is near the walls become utterly soaked by morning. Not really too sure what to do to combat it. 2 of the bedroom walls are external walls (semi detached house), the double glazed window in there is quite old (maybe 20 years) , and it has no trickle vents. Would trickle vents be enough to combat such strong condensation? The window is opened from time to time, but in this weather its difficult to have the window open without turning the room into an icebox.
Its only a small bedroom, but the kid (18 yr old) is in there, usually with his girlfriend of a night, so 2 people, big screen tv, double bed etc, so the room is quite crammed too.
Trickle vents may be the thing. The double glazing isn't the newest and doesn't have them. Can you just get them retrofitted into existing double glazing?
What's the heating like in the room? I just got used to accepting having the windows open and being cold if it reduced the condensation. Relative humidity should decrease with heat (in theory), so a few days running full whack with a de-humidifier might soothe the problem.
