XFX DD 290X benched at 4K - Stomps on 780Ti's
If H had of benched a couple of Sapphire Tri X 290X cards the fps would be even higher as the Sapphires have a small overclock applied to core and memory.
Urgh...maybe not this month lol.
Oh...well definitely **** that off then! LOL :D. Also threw me because they're 4GB. They're doing an NV number on those with the misleading naming scheme
£1,550.77 for 3 reference cooled 290X MSI cards with the EK blocks and back plates.
Whats happening in that BF benchmark between 111 and 131 to cause the 780Ti to drop to 30, yet the DD is way up at 80?
I'll probably get called out for saying this, but honestly at that resolution it could easily be VRAM. Especially with those settings. That's still speculation though, and it does bounce back fairly quickly so may have been something as simple as a system process caused the game to blip.
I am genuinely shocked they apparently didn't run into a frame buffer wall though on the Ti.
EDIT: Taking a second take I've realised they used 2XMSAA on the Ti, I'm guessing that's why. That's got to be the memory bus on the 290X taking over too.
I get tired of all this red vs green stuff, i mean am i the only one that thinks both teams got some great cards? the difference between them is not really worth shouting about, the numbers vary from one review to the next and can be different on any given day, less time benching and more time gaming i say :)
Great great results from the DD card, just slightly worrying that the 290X's throttle so much on stock clocks!!
Think it may be best if I strap some after-market cooling onto mine before the summer comes :D
Its about time you joined the Hawaii master race tbh Shanks. You won't regret the move to XDMA crossfire i promise you.
Am on it mate :D going to hang in till close to Thief release.
Cheers
May just have to give one of these a whirl :)
No problem, the cards for me have performed great. I have heard there rma is poor though so something to think about.
Interesting. :cool:
I've not seen them anywhere for sale in the UK so far. Mind you i only looked at here and scam so far. :p
Been looking at these for a while, yep I know they have a bad rep but you only tend to hear about the bad ones.
Plus, for me they are about the best looking ones.
Will have a closer look on their release
Does the XDMA make that much difference Matt? i'm hoping once mantle sorts out the irregular CPU frame rates my 7970s will be smooth enough anyway for 1080 @120Hz.
I'm running a Gene V as well so those hot 290s are only gonna get hotter with no spare slots between cards...
