I'm told that my area should receive fibre broadband within a few months after enduring years of speeds around 1Mbps. At the moment I have an Asus DSL-N55U purchased from Overclockers which I've found to be absolutely brilliant and massively helped stabilise my line speed.
However, from the research I've done so far, it seems that this router can't be used directly with fibre, is this true? Do I need some kind of fibre router which connects to the home line and then in turn to the Asus router? Is there a way in which I can buy an all-in-one Asus unit because I've just run cable specific for the router and don't fancy having two boxes with respective power etc?
I'm currently on Zen broadband and will be staying with them for fibre.
Thanks for the help.
