Picked up a battery charger for the bike whilst in hibernation.
I had one of these, quickly paid for itself using it on the car and motorbike, since moving country its still in use on my dads John Deere and TR6!
Got some friends coming over on Friday night, can't wait to crack this game out when the drinks are flowing![]()
Great game, but not sure of the replay value when you've seen all the cards a couple of times. I was tight and printed the free copy at work, then found you can print the add-ons and some community created cards too!
http://mdsc.info/dropbox/cah/
Lorax is an amazing film!
What's the airplay like in terms of connection reliability?
Bixler v1.1
40A ESC
D2826-6 2200kv 340W motor
6x4 prop
Just waiting for a CNC motor mount and a few bits before I glue and tape it up hence the velcro straps and things hanging off.
I've been practicing loads in Phoenix flight sim so hopefully it'll survive learning LOS so then I can kit it out with FPV gear.
Where did you buy them?
I got a Z a while ago as an upgrate to onboard... It sounds awesome in comparison and IMO the software that comes with it is much better than what comes with a comparable xonar.
Cheap 20kg dumbbell set.
