We got a big 6ft towel style radiator fitted to our Utility room about 3 years ago.
In that times its been a bit temperamental and seems to drip from the valves at the bottom. So every now and then i have a play and it seems to stop.
It started again the other day and won't stop. I've tried tightening the nut which connects the radiator to the wall pipe but its as tight as it'll go. Any more and its started to bend the pipe from the wall.
My next thought was to check that it had PTFE tape on the threads which i assumed would fix the issue. So i got a pan to catch any water and undid the nut. Water started pouring out the radiator and with only 2 hands i struggled to wrap the thread in tape. So i tightened the nut again to stop water pouring out but it's still dripping.
I then figured that the best option would be to drain the radiator to enable me to sort it. Then connect it up and re-fill. My only concern is the location of the radiator and the effect it'd have on the rest of the system.
The boiler is in a cupboard in the utility room and the pipes then dissappear into the wall. How can i work out whether the radiator in question is first in the loop or last?
When i disconnected the bottom left valve, no water seemed to come out of the wall pipe (i didnt shut off the water), only coming out of the radiator. Does that suggest that it comes from the right valve in the radiator, through the radiator and back out again from the left? If thats the case then should i just be able to shut off the valve on the right to stop more water coming in and then drain the radiator?
As you can probably tell i don't really know what i'm doing! But it doesnt seem like a big enough job to get a plumber out for!
