** A TRIO OF WHITE HOF CARDS FROM KFA2/GALAXY!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Posting this makes me very happy to see in true strength not only 1, or 2 but three HOF White PCB equipped cards from KFA2, designed to stand out, be unique and offer superb levels of overclocking. Check them out:-
KFA2 Geforce GTX 780Ti HOF 3072MB GDDR5 PCI-Express Graphics Card @ £559.99 inc VAT
The KFA2 GTX 780Ti HOF is produced with a white PCB, two 8 pin PCI-E power connectors for a maximum TDP, a Hyper boost button and Cooled with custom hybrid cooling solution - a combination of a Vapor chamber and heat pipes. Upto 20% performance gain Vs the standard GTX 780Ti and up to 10c cooler.
Specification:-
- GeForce GTX 780Ti HOF
- GPU: GeForce GTX 780Ti (GK110)
- Core Base Clock: 1020MHz
- Core Boost Clock: 1085MHz
- Memory Clock: 7000MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
Only £559.99 inc VAT.
ORDER NOW
KFA2 GeForce GTX 780 HOF 3072MB GDDR5 PCI-Express Graphics Card **ALL WHITE** @ £419.99 inc VAT
Exclusive to Overclockers UK we have the worlds fastest air-cooled GTX 780 - the KFA2 GTX 780 LTD OC or better known to some as the Galaxy Hall of Fame. With many premium and unique features such as Hyper Boost Hardware for maximum clock speeds and cooling. The first GTX 780 to use hybrid heat pipe plus vapor chamber cooling for near silent operation yet very low temperatures. Built and designed using 8+2 phase digital power, premium POSCAP and MLCC capacitors all based on a stunning white looking PCB. If you want the fastest GTX 780 on the market and one which looks different to any other, then look no further!
Features:-
- Hyper Boost hardware overdrive switch supercharges your core clocks
- World’s fastest air-cooled GTX 780 with 1058Mhz boost clock
- 1st GTX 780 with hybrid heat pipe + vapor chamber cooling
- Premium POSCAP and MLCC capacitors
- Winner of multiple overclock world records
- 8+2 phase digital power
- Voltage read points
- Custom white PCB
- Gigantic 3GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- Core Base Clock: 1006 MHz
- Core Boost Clock: 1058 MHz
- Memory Clock: 6008 MHz
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 2yr
http://hexus.net/tech/reviews/graphics/60001-kfa2-geforce-gtx-780-hall-of-fame/?page=12
Only £419.99 inc VAT.
ORDER NOW
KFA2 GeForce GTX 770 LTD OC 2048MB GDDR5 PCI-Express Graphics Card **WHITE EDITION** (77NPH6DT8KTZ) @ £287.99 inc VAT
The KFA2 GTX 770 LTD OC all white edition is produced with a white PCB, two 8 pin PCI-E power connectors for a maximum TDP, Overclocked. Cooled with custom white three 90mm fans and five heat pipes leading to an aluminum fin array. The result of this is a card which is quieter and cools better, whilst at the same time can also offer great overclocking ability. Then to finish it off this card looks absolutely amazing and is very unique with its all White Design including PCB, Fans and shroud.
Feature-rich and stacked with advanced gaming technologies like NVIDIA® PhysX®, TXAA™, ShadowPlay, and much more. This gives you the performance edge you need to take on next-generation titles like Splinter Cell: Blacklist and many others. It's serious equipment for the serious gamer.
Features:-
- White PCB, White fans, White shroud for that exclusive and unique look
- 2x 8-Pin power connectors for better TDP resulting in better overclocking ability
- Tri-Fan cooling, less noise, better cooling, longer lifespan
- Fastest GTX 770 out the box on the market with 1254MHz Boost Speed!!!
Specification:-
- Core Clock: 1150MHz (GK104)
- Core Boost Clock: 1202MHz
- Memory: 2048MB GDDR5
- Memory Clock: 7010MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2404MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 1x DisplayPort 1.2, 3x HDMI
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- 2x 8-Pin PCI-E Connectors required
- Hexus Review: http://hexus.net/tech/reviews/graphics/57949-kfa2-geforce-gtx-770-ltd-oc/
- Warranty: 2 Years
Only £287.99 inc VAT.
ORDER NOW
KFA2 GeForce GTX 760 HOF 2048MB GDDR5 PCI-Express Graphics Card (76NPH6DT8KXZ) @ £224.99 inc VAT
The KFA2 GTX 760 HOF all white edition is produced with a white PCB, two 8 pin PCI-E power connectors for a maximum TDP, Overclocked. Cooled with three custom white 90mm fans and five heat pipes leading to an aluminum fin array.
Specification:-
- Core Clock: 1110MHz (GK104)
- Core Boost Clock: 1176MHz
- Memory Clock: 6008MHz (Effective)
- Processing Cores: 1152
- Shader Clock: naMHz
- Display Connectors: 3x HDMI & 1x Displayport
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 170 watts at stock speed)
- 1x 8-pin & 1x 6-Pin PCI-E Connectors required
- Card Dimensions - Length X Width X Height: 268*124.3*41.5
- Warranty: 2 Years
Only £224.99 inc VAT.
ORDER NOW
Spot the deliberate mistake, actually 4 cards there, great to see these cards in numbers. :)
The 780 and 760 HOF cards are truly great looking and clocking!!
780 HOF doing 1300+ on stock cooler and 1800+ LN2 and 760 HOF doing 1950 LN2!!!
Good additions here mate.
1800mhz on ln2?!?! yikes I'd like to have some sort of all in one phase change gpu that could get near to that!
The 780ti HoF is more reasonably priced than I was expecting - considering the Classified is well over £600. Is that a pre-order only price?
And does it come with that beautiful backplate we saw when the first pictures were leaked?
How does the 760 compare to the MSI Hawk?
Its a better card to be honest. The Hawk though good is not a Lightning equivalent and HOF's are built to Lightning standards. They are extremely good, hence why so few apart. :)
Shall see how they sell, if they fly out then yes, if they are steady then we can hold price. Galaxy to produce huge amounts so sometimes they can be hard to get hold off like the 770 model was recently.
It's unfortunate the Galaxy cards are rarely reviewed.. Would be nice to have a direct comparison to classy :)
I'm sure they're great, and don't have the EVGA price premium.. but, 1 year less warranty.
Edit: Now that I look at it, the price is more than great if it matches classy.. :)
does the gtx780 come with the backplate, think its between this and evga superclock version, as i like the lights on the top of shroud, whats the fan noise like just running at stock load
