min 15L/second extraction with a 15min over run.
There's your problem.Well what's currently fitted (new build) is rubbish
Delta ehe, if you mount this, the torque it generates will crack your wall
They're seriously powerful fans![]()
I've just installed a Manrose in line centrifugal fan, shifts 240m3 per hour, which is around 70 litres per second. M100T I think was the model number, 60 quid on Amazon. Has a timer overrun too and is quiet for what it shifts.
The ManRose is the daddy. All others are gash. I can't stand the noise of a poxy extractor. Instead, we vented to the loft with the manrose's where basically a small windfarm spins up in ducting. Far more efficient and noiseless. Small grills above each shower = job done.
