- 13 Apr 2013
- La France
To save power on laptops, I guess.
I've tested this with 2 systems (as per sig) in BF4 and previously posted results.
Makes absolutely no difference in fps.
Did you find that it is only required on the intel chips?![]()
Funnily enough both the FX 8-core and the 3930k had parked cores in win7 ultimate 64![]()
If you run the program linked in the video, it will tell you if you have parked cores. Un-park them, reboot your PC (Won't take effect until you reboot).
That's it, done forever unless you want to reverse it with the program later on..
Worth mentioning that if you've disabled some power states in bios the program can wrongly tell you you've got cores that may be parked.
That's it?
gonna go home now and see if my 3770k has this on and our i3 lappy, can't say no to extra performance.
Been mentioned in the CPU forum for a while.. maybe needs sharing more.
It shows just how much parked cores has an impact, you can see the stutter in graph form lol. From what I've read the un-park core fix is even more effective on Intel, this is on an FX 8350. Metro LL test.
Cores 1 3 5 7 are parked :O
