Anyone running titan's in sli?
Kaapstad how much was your whole watercooling loop?
Near 1k mark?
For the Titan setup
3 x 480mm AX XSPC rads
4 x XSPC waterblocks
4 x XSPC backplates
1 x XSPC CPU waterblock
1 x XSPC Dual D5/Res combo
Yes getting close to 1k mark
Nearly all of it from OCUK
Unfortunately XSPC don't make the chrome plated CPU waterblocks anymore which is a shame.
I have used EK waterblocks and backplates for my 290Xs, I have seen a pic of these on BattFink Titan's and they look stunning.
http://forums.overclockers.co.uk/showpost.php?p=25762067&postcount=231
I thought it would be the other way around? More cards means more rads and fans? And a stronger pump to feed both cards?
It does but for two cards a single Laing D5 pump will be more than enough where I have to use two of them for example. For rads and fans you only need to use half the number I have used and so on.
Ah I got ya :) what case you using? I have a 750D so no idea what kind of potential it has :)
I use several cases
Corsair 900D and 800Ds
LD V8 Reverse.
I don't know much about the 750D but if you post in the watercooling section the people there know a lot more than me about your case and are very helpful.
Just had a look on the OCUK product page and the 750D looks like a really good case.
£460 :cool::cool:
