im not entirely sure tbh
we had 30 of each G10 land today.
the only one that hasnt had enough to fulfil all of the back orders is the white version.
if you have a white one on order and want to swap it to red/black then we can do that
any idea if you will get any refurb corsair coolers to go with these would be nice![]()
RJK could you possibly ask your tech lab people they may know as they build the cards![]()
These are interesting. (Okay yeah that was just to make my post semi-relevant...)
New sig cos you have a new car RJK or was your VTEC "BWAAAAAAAH" always coming from an S2000?![]()
Some form of deal with bundled coolers would be totally awesome! Or as above, some refurb compatible coolers would be amazing.
On some colours. I believe that the white may have all gone. Stock levels on the website should be accurate.
Will check once I'm at work in 20 mins or so.![]()
white - no stock
red - around 19 left
black - 7 left
Is the website correct? 10+ stock Red, 10+ stock White, 4 stock Black?
red = 19 left
white = 16 left [was booked in after i posted]
black = 3 left
gibbo doesnt look after cooling.
I do.
EK Water Blocks EK-VGA Supreme HF Copper Shim @ £3.95 inc VAT
A 0.5mm thick copper plate adapter which fills the height gap between the AMD Radeon HD 7970 / 7950 series GPU and the surrounding metal shim.
This use of this copper adapter is mandatory in order for EK-VGA Supreme HF series water block to make proper contact with the AMD Radeon HD 7970 / 7950 series GPU. Also useful for installation of extreme cooling solutions (e.g. liquid nitrogen evaporators).
Notes: Please use thermal grease on both sides of the adapter plate (not included - we recommend Arctic Cooling MX-4)
Technical data:
- Dimensions: 28.5 x 28.5 x 0.5 mm
- Material: Copper
- Application: Radeon HD 7970 / 7950 GPU
- Mounting: Clamp force between GPU and water block
Only £3.95 inc VAT.
ORDER NOW
