Razer Themed Air 540 Build
19 Feb 2007
Northampton
Another One For My Fellow Razer Fans
Rig Specs -
Intel Core i7 4770K @ 4.80GHZ
Asus Sabertooth Z87 TUF
32GB Avexir Venom Green 2400MHZ
EVGA GTX 780 Ti SC 1200/3800 *Second On The Way For SLI*
Asus Xonar Phoebus
Killer NIC 2100
Corsair Neutron GTX 240GB Raid 0
Western Digital Caviar Black 2TB
Western Digital Caviar Black 4TB
Corsair H100i + 2 x Corsair SP120MM + 2 x Corsair AF 120MM
Windows 7 Ultimate 64 Bit Edition
Corsair Air Flow 540 + 3 x 140MM Bitfenix Spectre Pro Green LED Fans
Dell Ultrasharp 27" 2560 X 1440
Peripherals -
Razer Blackwidow Ultimate Elite
Razer Sabertooth
Razer Ouroboros
Razer Tiamat 7.1
Razer Goliathus XXL Speed Edition *New And Old Version*
Razer Orbweaver
The Air 540, I fell in love with it when I saw it in person, Had to get it.
Replaced the fans at the back and front with Bitfenix Spectre Pro Green LED 140MM's.
Night shots *Taken before most of the work was done* -
Also painted the fan rings on the 2 x Corsair SP 120MM fans so they blend in more -
Installed 3 x of these on the 2 x Front/1 x Rear 140mm Bitfenix Spectre Pro Green LED Fans, Covered the frames in carbon Fibre Di-Noc and also put some Di-Noc on to the centre of each fan for uniformity and then neatened it up with a precision blade -
Took apart my Neutron GTX 240GB and sanded the metal shell, Primed it, Painted it, Baked it for 2 hours in the oven and then let it cool and sit for 2 hours, I think it came out quite well.
I then put it back together and gave it and the WD Caviar Black 4TB some Di-Noc love ^_^
*The other 2TB HDD and 240GB SSD are both in the rear compartment*
Made an SLI finger cover from an old SLI bridge, Took off the ribbon, Sanded and cleaned both parts, Stuck them on to black plastic card, Put some Di-Noc on to it and then neatened it up with a precision blade and model file -
The backplate for the 780 Ti -
The backplate for the 780 Ti installed :) -
Replaced all Sata cables, Fan cables 8 Pin EPC etc... with Green Bitfenix braided cables apart from the PCI-E and 24 PIn Power cables which are custom Green and Black braided cables -
Got some cable combs for the 6 Pin, 8 Pin and 24 Pin cables, Nice and neat, Might get a couple more though, Also the Razer etched glass effect decal arrived and it's on the inside of the window for a cleaner look -
Here's The Desktop -
New additions are the Razer Orbweaver -
And the Dell Ultrasharp 27" 2560 X 1440 -
And finally, My corner of happy :) *Please excuse the quality, I think my camera is on it's last legs* -
such a awesome build!
How did you get that Windows theme? like your quick launch icons are in a little box?
Thank you :)
The theme is from megathemes - http://www.megathemer.x10.mx/
A bunch of artists basically made a site and share their themes this being one of them but I've customized it a lot, They do more than just windows themes though, Sound packs, Dreamscenes for windows 7, Custom icons, Rainmeter themes, Tutorials, And a lot more custom stuff.
And you can also get custom items done :)
Their site was originally called CreativeX but an idiot hacker thought it was a fantastic idea to ruin it for everyone.
The quick launch programme is called Rocketdock and there are hundreds of different styles and icons available, 1.3.5 is the latest -
http://rocketdock.com/
Love that GPU Backplate
Thank you, It's from Coldzero, Considering he has done a lot of work for people on these forums I'm hoping it's ok to share his link seeing as he's not a competitor - http://www.coldzero.eu/
i iz green :P
well done dude - like what you did with the ssd/hdd's. Need to do something similar to mine to try and hide the fuglyness of the hard drive lol
