I tried using MS Money for a bit, but it's way too difficult to set up. Takes hours.
Time consuming != difficult. I've spent hours setting mine up but that was because I've been working out the best way to do things and find the information that I want to see. Once set up I probably spend 30 minutes a month over a couple of sessions adding transactions. As said, I would highly recommend everyone use it as you will be aware straight away of anything that is amiss and helps loads with future planning.
Thanks although I think from memory she uses a Mac! SHould have said that in the opening post!
I guess vmware or whatever is out of the question then.
I still use MS Money and the OFX file export from Nationwide works fine for me. There was a time it produced incorrect OFX files but that's now fixed. The only annoyance is you need to download per account.
The online experience of Nationwide has a lot to be desired, I only use the account for salary and direct debits so is **** easy to maintain in Money, only need to add any overtime in as the rest is automatic (except for a quick glance through the mobile app to make sure it is correct).
