I don't quite understand the two sets of three 140MM fans of different types?
Other than that there doesn't seem to be anything wrong with it.
Never been a fan of MSI boards, but I haven't had a recent one so they might be OK now...
The 2 sets of 140 fans I chose as I wasnt sure if just to get the corsair or get the bitfenix pwm and then get a fan controller or are they not really needed?
Ok so ill stick with the 3 bitfenix 140 fans and I had the corsair sp120 pwm duel pack for the h105. I like the idea that danny75 linked to the akasa flexa fp5 cable , if someone would be able to do a basket with everthing I listed and include all the red extension cables I would need for the bling I would be really grateful
This is my fan solution recommendation, and it includes white LEDs already, so you get red fan and white light at the same time. Probably wouldn't be a need for more white light.
YOUR BASKET
6 x Zaward Golf III Fan 120mm PWM LED ZG3-120B - black/red £10.98 (£65.88)
2 x Akasa FLEXA FP5, Smart PWM cable for 5 PWM case fans. (AK-CBFA03-45) £4.79 (£9.58)
Idea would be to set the two radiator fans on the first PWM splitter, and the four case fans on the second splitter. Necessary, as there'd be six fans not five, but the good thing is that you can give each fan header different settings if you need to, to get the balance between cooling and noise right. i.e. There's no need to have case fans blasting at 2000 RPM along with the CPU fans (when the latter need to).
The board has dual cpu fan headers so you are ok for the cpu fans. I think you would only need 1 splitter cable for the front fans, and the rear fan would run off it's own header.
Won't the pump fan need to use one of the two CPU fan headers? If the H105 is anything like the H100i. Just asking, you might know of another way.
Although the idea behind using one splitter (then two as it turned out) was also to have less clutter on the mobo.
If the pump & fan(s) are supposed to share a header (unsure if this is the case with the H105) I personally prefer to give them separate headers to ensure they are getting enough power. I had issues with a CLC before (the pump was rattling) and it was cured by using two headers instead of one. (pump separate to fans)
