- 1 Mar 2008
- York
Has anyone done the above?
I may try it out?
I may try it out?
On another subject....
...if you want to get creases out of suits lock them in a shower room with the shower at full heat and running. I **** you not, it works.
...now, back to this catastrophe in the making![]()
Cleaned the interior of the car today with great results��
Why bother with dash cleaner? With the power of steam
Main reason for me would be to not get moisture in the climate or audio controls or sensors for the climate. Second reason would be to make sure I didn't introduce moisture that would then condense on the glass overnight.
Yeah it's not like the dirty water solution you create is actually taken out of the car!
