Water Cooling AIO in Corsair 250d
2 Jan 2014
YOUR BASKET
1 x Corsair Hydro H90 140mm High Performance Liquid CPU Cooler (CW-9060013-WW) £69.98
1 x Corsair Hydro H60 V2 High Performance Liquid CPU Cooler £54.98
1 x NZXT KRAKEN G10 GPU Cooling Adapter - Black £29.99
1 x Noctua NF-A14 FLX Fan - 140mm £19.49
1 x Noctua NF-F12 PWM 120mm Focused Flow PWM Cooling Fan £15.98
1 x Noctua NF-B9-PWM 92mm Quiet Case Fan £14.99
2 x Noctua NF-R8-PWM 80mm Silent Case Fan - PWM £13.99 (£27.98)
Total : £243.00 (includes shipping : £8.00).
This is what I might be buying. The H60 + NF-F12 are for the CPU (Athlon X4 760K), the H90 + NF-A14 FLX + NF-B9-PWM + NZXT Kraken G10 are for the GPU (R9 270X) (I will be buying VRM and RAM heat sinks as well becasue It improves vrm temps dramatically) and the 2 x NF-R8-PWM are for exhaust from the case. Would this be a good way to go? And would the G10 fit in the Corsair 250d as it is a 2 and a half slot cooler?
The H60 will be mounted on the dual 120mm fan side (the right, since the radiator is 120x152x27 will I be able to put another 120mm fan next to it?) And the h90 will be mounted at the front of the case.
The radiators would all fit, but I seriously doubt the G10 would. Even if it did, with the amount of money you're spending on it I would just get a 280X instead. I realise a 270X plus Kraken won't cost you quite as much as a 280X, but it does make the step up reasonably small considering the extra performance you'd get.
You *might* be able to fit the Kraken G10 in there as it appears to be 2 slots + some breathing room for the card. However it would be a very tight fit or you'd need to mod the kraken or case to make it fit.
Any particular reason why you want to use the G10 on a 270X? You could upgrade something else in the system for the £99~ you'd save ;)
Also you might want to remove the ebay link before the mods come along, these heatsinks are cheaper anyways :)
YOUR BASKET
1 x Alpenföhn Passive DRAM / VRAM Chip Coolers £11.99
Total : £14.27 (includes shipping : £1.90).
YOUR BASKET
Thank you for the link to those heatsinks :) I removed the link
What should I upgrade instead? I am still going to water cool my CPU with the h60 or h100i. And I'm not really sure why I wanted to use the g10 just love the idea of water cooling but don't want my own loop... Scared xD
