Nom nom nom.
Powertap SL+ built onto my Fulcrum 7 rim with DT spokes. I figured a training wheel is never going to be very light, this added approximately 50g at the hub, but then the spokes may be a few g lighter. Neither here nor there really, and I want some fancy wheels to race on but big $$$. This wheel cost me fully built including the hub <$500. The Garmin Vector pedals are $1250 new and a new Powertap wheel similar, a Quarq/SRM is $2k+.
I tested it and it works which is good since it was second hand! Removed my Garmin speed/cadence sensors as the Powertap should do that as well, but if it proves to not be as accurate I may put them back on.
Had a quick spin round the block, but forgot to connect the Garmin to satellites as I had been using it in the garage. Power figures look about as expected, averaged 235w for a 10 minute run about town inc some small hills.
Wondering if there is a quick method to calibrate the Powertap before each use, as it takes quite a long time to go through all the menus to get to the calibration screen.
Some Cervelo pr0n too. I know I need an out front Garmin mount!
Worryingly I noticed this while putting the wheel back on the bike... sidewall is fatigued/aged it looks like!
don't worry you wont gain fat as long as you stay active and don't over eat too much/at all if you still want to lose weight.
