Hey all, first post here
Sorry if this seems long winded, I was just hoping someone here might be able to give some guidance~
On the weekend I ordered a pair of Roccat Kave 5.1's http://www.overclockers.co.uk/showproduct.php?prodid=SP-000-RC to replace my old rattling BeyerDynamic DTX800s and Logitech microphone held together by tape (Both did me well, sad to see them retire
But the Kave 5.1's are constantly hissing with static noise. I can't have the volume sliders on the Tip'n'slide remote any higher than 1/3rd of the way without it becoming unbearable.
Along with the static and hissing, whenever I move my mouse it will 'whine' (Kind of like a GPU squeal when your FPS are too high). My old pair of headphones did this too, but nowhere near as bad as the Kave's, (which I would guess because it has a built in amplifier that is... amplifying it.)
Specs down below:
Intel i5 3570K (4.4GHz)
Gigabyte GA-Z77-D3H (Audio VIA VT2021)
12GB DDR3-1600
Sapphire HD5850 1GB (Stock)
60GB Vertex II
500GB WD Black
2TB Samsung F4
Windows 7 x64
I am pretty sure this is EMI from my onboard sound (VIA VT2021), but before I did anything else I tried a few other things:
- Driver updates.
- Moving anything that could cause EMI out of the way (Power cables, router, etc)
- I tried using a few AC USB chargers.
- Unplugged my front USB/Audio on my case.
- Double checked cables were seated properly.
- Undid my overclocks and having my CPU/Mainboard/GPU running at stock.
Unfortunately none of this helped to lessen the static and mouse whining.
To rule out it being a fault with the Kave's, I tested them on my tablet (Nexus 7) while the amplifier was still plugged into the PCs USB. I tested each channel/jack while playing some music. And huzzah, there was no static, hissing or popping. I could max the sliders on the Tip'n'Control remote and everything was crisp and clear.
So this must be an issue with my onboard audio?
I am worried about getting a dedicated sound card like the Xonar DG/DS or Creative Audigy SE/FX if it doesn't stop the EMI.
I'm a little unsure where to go from here.
Would getting a Xonar or Audigy would be the right step to take now?
Has anyone else in the past had this issue with onboard audio and EMI?
Thanks in advance!
EDIT: Also realized I buggered up the post title, haha. Someone able to change that to Kave?
Specs down below:
12GB DDR3-1600
60GB Vertex II
500GB WD Black
2TB Samsung F4
Windows 7 x64
- Driver updates.
Thanks in advance!
