Low profile cooler advice
28 Jan 2014
Hi Guys, I'm after a bit of advice and some opinions.
I have a MB bundle from overclockers that is running an intel i5 at 4.3Ghz but the cooler that it came with is just fractionally too tall for my case. So I have agreed to get it exchanged (thanks OC).
I don't really want to change my case so I'm looking at low profile coolers. The max space I have for the cooler at a push is L 180 x W 180 x H 140. So plenty of width and height just not much in terms of height. I have 4 that I think will do the job but just wanted to see what people thought of them. In order of preference (at the moment) they are:
Enermax T60-TB Silence Top-Down CPU Cooler
Noctua NH-C12P SE14 CPU Cooler
Be Quiet! Shadow Rock Topflow SR1 CPU Cooler
Phanteks PH-TC14CS CPU Cooler - Red
The last two will be a little tight on the height which is why I favour the first two.
Cheers :)
Does your case have a 120mm fan mount? if so, have you considered an AIO cooler such as the H80i / Antec 950
http://www.overclockers.co.uk/showproduct.php?prodid=HS-014-CS&groupid=701&catid=2330
http://www.overclockers.co.uk/showproduct.php?prodid=HS-011-AN&groupid=701&catid=2330&subcat=2359
There are many other AIO coolers on ocuk, check em out.
If your case will not accommodate such a cooler then I'm sure others will be along to advise on a low profile one, that NH-C14 recommended above would be a good choice if it fits. What case are you using?
I would love to run water cooling, but my old case simply will not support it. could change the case but the Cooler Master Wave that I have is still in fantastic condition and I'm not tired of it. I'm going to increase the ventilation with a few changes to help things as you can add a top vent.
