** Raijintek Nemesis & Themis Evo **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Announced today, we have the excellent new coolers from Raijintek arriving soon.
The Raijiintek brand is becoming synonymous with epic performance at great price points and these two are no exception.
Both the Themeis Evo and Nemesis feature trademark German engineering that has defined Raijintek in the market. Signature Red and white fans adorn both CPU coolers adding a stylish flair amongst the uber efficient CPU Coolers.
Raijintek Nemesis Dual Element Extreme CPU Cooler @ £49.99 inc VAT
Nemesis is designed as a flagship cooler, featuring high performance copper base and high flow fins, the Nemesis pairs performance fans to ensure maximum heat dissipation.
Features:
- 100% Nickel heat-sink, efficient 8mm Heat-pipe*6 & Dual-tower extremely large dissipating area
- Dual 14025 fans pre-installed ;
- 14025 PWM fan - Low noise & outstanding air flow as well pressure
- Multiple mounting kits for INTEL 2011/1366/1156/1155/1150 & AMD AM2/AM3 .
- Special hole design on fins to provide excellent air flow and cooling efficiency .
- Triple fans installed option and anti-vibration rubber attached.
- User friendly design - Multiple socket compatibility , triple fan option and anti-vibration attached
Specifications:
- Dimension: 140(W) x 130(D) x 166.5(H) mm
- Heatsink: Patented Copper base. Fins - Aluminum Alloy; soldering
- Fan Voltage Rating: 12V (0.13 Amp)
- Fan Starting Voltage: 7V
- Fan Speed - 600 ~ 1000 R.P.M. (PWM) - 1000 R.P.M. (w/o PWM)
- Air Flow - 70.2 CFM (Max.), 1 fan
- Noise Level: 23 dBA
Only £49.99 inc VAT.
ORDER NOW
Raijintek Themis Evo Professional CPU Cooler @ £27.95 inc VAT
THEMIS Evo, "Designed in Germany", is manufactured by several patents to reach advanced performance, high quality & workmanship, environmental protection and ease of use. With Anti-vibration rubbers and supporting all modern sockets, THEMIS Evo is your professional choice of cooling.
Features:-
- Non-Copper base design (C.D.C. - CPU Direct Contact)
- Patented pressing heat-pipe/fin technology to prevent the risk of heat-pipe damage
- Patented solder-less louver fin assembly to increase heat-pipe ventilation
- 100% Nickel heat-sink design
- Compatible with all modern sockets of INTEL & AMD at market
- Anti-Vibration rubber used to minimise movement and noise
- Large dissipating area & elegant fin design
- Easy installation and user friendly
Dimensions: 122x82x165 mm
Weight: 614 g [Heat Sink Only]
Thermal Resistance: 0.11 °C/W
Heat Sink:
- Base Material CPU Direct Contact [C.D.C.]
- Fin Material Aluminum Alloy; Solder-less fins assembly; Nickel
Heat-pipe :
- SPEC F8mm
- Q'ty 4 pcs
Fan :
- Dimension [WxHxD] 120x120x25 mm
- Voltage Rating 12V
- Starting Voltage 7 V
- Speed 1000~1500 RPM [PWM controlled]
- Bearing Type Sleeve Bearing
- Air Flow 43.8~65.68 CFM
- Air Pressure 1.0~2.24 mmH2O
- Life Expectance 40,000 hrs
- Noise Level 24.53 dBA [Max.]
- Connector 4 pin with PWM
Only £27.95 inc VAT.
ORDER NOW
Yeah looked like the Nemesis is trying to compete with the K2, though the K2 fans move a bit more airflow, looks very cool though.
As mentioned love to see some reviews.
Fan :
Will these fans be available seperatley? The only Raijintek you stock is the 140mm 'Aelous' (spec below) but the ones on these coolers (both 120mm?) have much higher CFM/Pressure!
- Dimension: 140x150x13 mm
- Voltage Rating: 12V
- Starting Voltage: 7V
- Speed: 650~1400 R.P.M. [PWM controlled]
- Bearing Type: Sleeve Bearing
- Air Flow: 44.43~56.55 CFM
- Air Pressure: 0.76~1.24 mmH2O
- Life Expectance: 40,000 hrs
- Noise Level: 28 dBA
- Connector: 4 pin with PWM
potentially. it depends what raijintek want to do with their releases
These 120mm fans would fit well on the Morpheus (great static pressure), worth hinting to Raijintek Rich? ;)
