Man of Honour
- 5 Oct 2008
- Kent
As to whether they do anything to the 183 its a tough one. The gun with hesh is a little silly for the amount of damage it can do, but its not a tank where you can point anywhere and do 1750 damage, unlike a lot of the T10 td's firing heat. You are actually required to aim at weak spots with the tank.
If they nerf HESH they need to increase the ammo capacity of the tank and reduce the reload. However I don't think they need to do this as you do need skill to actually one shot things as you say, ie you need to aim at the weak spots. Even when you do this you can get trolled by missing the weak spots or by hitting spaced armour...and doing only around 600 damage.
