- 11 Dec 2005
- Cheshire
The highlights of this week's deals are as following:
This week we are offering the Asus GeForce GTX 780 Poseidon DirectCU H20 3GB graphics card for only £479.99 inc VAT. Whether it is air or liquid cooling you prefer the Poseidon is adaptable whilst delivering crushing graphical performance.
Revel in next generation sound with the Creative Sound Blaster X-Fi Titanium HD Sound Card pumping out the studio quality audio for only £94.99 inc VAT.
Enjoy a panoramic 27” view of the computing world with the Iiyama Prolite XB2779QS-S 27” AH-APS professional LED Monitor. Supporting a huge 2560 x 1440 resolution and yours for only £419.99 inc VAT.
Want more? Our whole selection of deals HERE.
Iiyama Prolite XB2779QS-S 27" AH-IPS Professional Widescreen LED Monitor - Silver/Black @ £419.99 inc VAT
Featuring WQHD (2560 x 1440) resolution, the XB2779QS can display almost 77% more information on the screen than a Full HD display. Users can create their own workspace by displaying and manipulating multiple applications at the same time. The AH-IPS matrix guarantees high performance with accurate and consistent colour reproduction, wide viewing angles and a fast response time. An array of inputs including HDMI, DisplayPort, DVI and VGA connections ensures compatibility across a wide range of mulitimedia devices. The XB2779QS is perfect for demanding users who settle only for the best specifications and modern design.
With true WQHD 2560 x 1440p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen, i.e. over 76% more in comparison to a 1920 x 1080 monitor.
The AH-IPS panel technology guarantees consistent colour reproduction with wide viewing angles and high contrast and therefore it is especially recommended for graphics design and other applications which require colours to be displayed accurately. The response time of the panel allows for smooth playback while watching films and playing games, making the IPS the best all-round technology suitable for both business and home use.
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals.
A Height Adjustable Stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity.
Specification:-
- Diagonal: 27"
- Panel: AH-IPS LED-backlit
- Display area h x w 335.7 x 596.7 mm; 13.2" x 23.5"
- Response time: 5 ms
- Contrast: 1000:1 typical
- Contrast: 5000000:1 ACR
- Brightness: 350 cd/m² default, 440 cd/m² typical
- Viewing zone: horizontal/vertical: 178°/ 178°; right/left: 89°/ 89°; up/down: 89°/ 89°
- Display colour: 16.77 million
- Pixel pitch: h x v 0.233 x 0.233 mm
- Native resolution: 2560 x 1440 ( 3.7 megapixel)
- Horizontal sync 30 - 80 KHz
- Vertical sync 55 - 75 Hz
- Synchronization Separate Sync
- Aspect ratio: 16:9
- Colour range: AdobeRGB: 86%, sRGB: 116%, 82% (NTSC)
- Connections: VGA, DVI-D, HDMI & DisplayPort
- HDCP: Yes
- Dimensions: w x h x d 650 x 435.5 (564.5) x 230 mm
- Weight: 8.2 kg
- Warranty: 3yr
Only £419.99 inc VAT.
ORDER NOW
Creative Sound Blaster X-Fi Titanium HD Sound Card (70SB127000001) @ £94.99 inc VAT
The Sound Blaster X-Fi Titanium HD provides the highest quality audio playback of any sound card Creative has ever introduced and includes THX TruStudio PC audio technology, bringing together two of the most respected names in sound quality to provide an unparalleled audio experience on the PC. The Sound Blaster X-Fi Titanium HD features audiophile-grade components for high-quality playback of music, games and movies, including 122db SNR Digital-to-Analog Converters (DACs), the highest signal-to-noise ratio ever produced by a Creative sound card. Replaceable OP-amp provides the flexibility to further customize the audio experience through different sound coloration. If you are serious about your PC sound, this is the ultimate Sound Blaster experience.
- High-Fidelity audio performance D/A, A/D converter with SN ratio of 122dB with 0.001% (THD) distortion
- High quality audiophile grade performance components designed to eliminate noise, while dramatically improve sound field dynamics in high and mid tones
- Headphone out with 115dB, 24bit/96kHz support High-Definition (HD) quality sound for original playback
- Personalize sound field experiences with swappable OP-amp sockets
- THX TruStudio PC effects transforms your experience into a true High-Definition (HD) multimedia emotional journey
- Hardware-powered 3D positional audio and EAX 5.0 effects provide stunning audio realism over headphones and speakers
- ASIO recording support with latency as low as one millisecond with minimal CPU load. Dolby Digital and DTS encoding enables one-step single-cable connection to home entertainment systems, with included optical cables
Only £94.99 inc VAT.
ORDER NOW
Asus GeForce GTX 780 Poseidon DirectCU H20 3072MB GDDR5 PCI-Express Graphics Card @ £479.99 inc VAT
ASUS Republic of Gamers (ROG) today announced Poseidon GTX 780 with GeForce® GTX 780 GPUs and exclusive DirectCU H2O hybrid thermal solution delivers 140%-cooler, 3X-quieter and 12% faster gaming performance. DirectCU H2O technology employs a combined air and water channel to provide complete flexibility for the user. A custom vapor chamber is in direct contact with the cards' GPUs for faster heat dispersal, while copper heat-pipes and extended cooling fins further transfer heat out and away from the cards to keep them running cool. With water cooling, ROG Poseidon graphics cards achieve up to 24°C-lower running temperatures than reference design. In addition, with standard G¼-inch threaded fittings, ROG Poseidon GTX 780 easily accommodate existing cooling equipment - so users can get going with water cooling right away. For enhanced overclocked headroom and gaming experience, ROG Poseidon GTX 780 is loaded with DIGI+ VRM, 10-phase Super Alloy Power and Japan-made black metallic capacitors. The bundled ROG Edition GPU Tweak utility provides real-time intuitive graphics tuning and easier overclocking. A simple online-streaming function lets users share gameplay live - so people can watch as you play. ASUS POSEIDON-GTX780-P-3GD5 provides fantastic gaming experience!
Designed to provide superb performance on air or liquid, the ROG Poseidon graphics card incorporates DirectCU H2O to give you the flexibility and freedom of choice. Liquid cooling has been a choice for many PC enthusiast as a efficient means of heat removal and increased overclocking potential of carefully selected hardware. However, custom water cooling solutions can be difficult and costly, as original cooling solutions have to be removed and fitted with waterblocks. The ROG team engineered the Poseidon with revolutionary DirectCU H2O to give you the best of air and liquid cooling- providing total flexibility whether you are looking to liquid cool now or later. Venturing into liquid cooling with the Poseidon reduces GPU temperatures by up to 24°C and enjoy ultra-stable overclocking!
Specification:-
- GPU: GeForce GTX 780
- Core Base Clock: 863 MHz
- Core Boost Clock: 902 MHz
- Memory Clock: 6008 MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
- Tech Spec: http://www.asus.com/uk/Graphics_Cards/ROG_POSEIDONGTX7803GD5/
Only £479.99 inc VAT.
ORDER NOW
Specification:-
- Diagonal: 27"
- HDCP: Yes
- Weight: 8.2 kg
- Warranty: 3yr
ORDER NOW
ORDER NOW
Specification:-
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
ORDER NOW
