I am an electrician myself but i moved over to instrumentation side and mainly forgot what i knew so ill explain this simply
I currently have an old wire fuse board one circuit which is running a 6mm Twin through an outside wall (which has now been converted into a garage) across the wall and in again through the top into a cooker switch to power the oven.
I am wanting to tap into this supply to power the garage as i cannot fit another pair of mains tails safely to go into a separate board and i have no spare ways left on my existing board. The garage will have a ring main on that is all (Lighting is already run in from house wiring (Been there years as it was a car porch way)
Now would my thinking of uprating the cable to the new board to a 10mm twin and earth and running my oven feed from an mcb in the garage distribution board actually be acceptable? This is a job for my parents not for me.. I know how id do it but they want it cheap as possible and i don't want to take any stupid risks as we have no isolator on incoming tails and i won't rip the main fuse out
Advice/Opinion is appreciated im stuck here on how else this could actually be done.
 (well legally anyway
 May be out question
 May be out question
