Need a molex to pci-e connector - could I just make one?
16 Nov 2011
My PSU recently died, I have managed to borrow one but it only has a single pi-e connector. It also has two Molex connectors, so would making one with wires be safe and advisable?
Also the PSU is a Alphapower ATX-850L, I can't seem to find anything about this PSU online, I'm a bit worried that it is a really cheap PSU and might take out my system.
It sounds like an el cheapo to me. Is it an 850W ? and what are your system specs
I must admit I have never heard of Alphapower. Also a good quality 850W psu would have 4 x pci-e cables. The fact that yours only has 1 is not a good sign.
Can you see the sticker on the side of the psu ? You want to look at the 12v rail and see what the total wattage and amps are. A good quality unit will be able to deliver 800W+ on the 12v rail.
Here is an example -
http://www.jonnyguru.com/modules/NDReviews/images/SeasonicM12IIEvo850/DSC_9818.jpg
The 12v rail can deliver 840W and 70A.
2x 24A so that's 576W, also my old decentish 750W toughpower 80+ gold only had one, but I think that was because it was a goodish PSU that was made a bit cheaper.
+5v 38A
+3.3v 30A
+12v1 24A
+12v2 24A
-12v 0.5A
+5vsb 2.5A
I have a junk alpha power rated at 650 with NO pcie. Wouldn't trust it, even if the rails on the sticker show it capable to run a small system. Only use it to fire up pumps during leak tests.
Power supplies are things people often love to get excited about and massively over spec.
True, some PSUs are total junk, but the way people attribute price to quality has gone beyond silly.
But the thing about PSUs is that if you choose right it will last you multiple systems and you will have the piece of mind that it will not go wrong, and if it does you RMA it.
I think a lot of it also depends on the manufacturer in question. Some like Enermax are very expensive, whereas Superflower who are on par are priced very well.
Example being:
YOUR BASKET
1 x Enermax Platimax 1000w '80 Plus Platinum' Modular Power Supply (EPM1000EWT) £229.99
1 x SuperFlower Leadex Platinum 1000W Fully Modular "80 Plus Platinum" Power Supply - Black (NESF-010) £161.99
Total : £401.58 (includes shipping : £8.00).
Example being:
YOUR BASKET
The AX850 that I have\had was one of the best on the market. Anything that is a Seasonic is very good.
Flextronics are a good oem. I am referring to the lower end Corsair stuff that used to be Seasonic. They now seem to be using cheaper oem's like Greatwall.
To be fair the lower end is no place for Seasonic, lower end as in price \ performance of course.
