That's how it goes Kaap. One always seems enough to those who've not tasted two, then two always seems enough to those who have tasted three...and so on.
+1
Crysis 3 - The Way It's Meant to be Played.
+1 I would put up with one card for a while and go SLI when l had the money for the other.
mad ? hardly, you just bought the best cards around, rich ? probably![]()
+1
Went SLI recently, kind of regret it kind of don't. The extra heat generated and overclocking isn't really a problem nor is the noise I just pray you don't run into the GPU usage issue like me (Given you have an i7 i guess you'll be fine)
For the record 750w is plenty! the 670's + clocked cpu and the rest still only hit around 560w at the wall so you will be fine
Enjoy! I only bought a 290X at Christmas but my mind is already full of Crossfire dreams!
GTX780Ti aint anywhere near enough above 1920x1200 in recent games so you made the right choice.
Those extra pixels become much harder to render/manipulate so PCI-E bandwidth gets hit much harder IME you need the fastest cards & CPU you can afford above 1920x1200 as games are not optimised for it so it takes a lot more power to give a smooth experience with max gfx details.
