Dashboard on the blink
17 Aug 2009
Finchley, London
I've booked my car at my regular garage to be checked out tomorrow. There's a problem with my main dashboard computer in my old 307 HDi.
Last night, these warning lights, including ESP, came on and stayed on, with the stop light flashing.
I continued my journey, got there, turned the engine off, went to do some work, came back to my car half an hour later and all was normal again on the dash and stayed normal as I returned home. It was fine this morning too on my next journey.
On my way home this evening, a few minutes into the journey, the same lights came on again, plus all my mileometer readings had now gone, just dashes, plus the low fuel light was now flashing, even though I have well over a quarter of a tank. Then about 20 or 30 minutes later, the water gauge, rev counter and speedometer stopped working. I had no idea of what speed I was doing anymore, so drove slowly. Left and right indicator arrows were not showing up on the dash either, but I checked outside the car and the indicators were all working.
Got home, turned off the engine and lights. These dashboard lights remained on. Went into my house for a few minutes, came back to the car to drive it to the garage in my street, and the dashboard was again completely back to normal. Even the mileage readings were intact.
I've had intermittent problems like this before. After my alternator was replaced a few months back, the battery warning light was still coming on. But after a few days, it disappeared.
Can I be optimistic and hope it's just a loose connection somewhere? I've got three long journeys tomorrow, saturday and sunday, and have had to make contingency plans in case I don't get my car back for a day or two. :(
At the moment, it seems to go back to normal after switching off and waiting. I could risk using the car, but I'm just worried that it might go kaput altogether and I'd be left with no speedometer.
My ST can do weird and wonderful things when the battery is getting low. Could it be the same on your car? Have you checked that?
Had similar issues on a Pug 406 & it was the solder on the back of the instrument cluster cracking in various places.
Ah, maybe it's that then. Is it a difficult/lengthy/expensive job for them to get access to the cluster? Soldering should be easy enough for them to do though, if it is that?
I know you'll want / need to get it fixed but is binning this thing an option? They are truley terrible cars as you've found out.
Could be various things but a short of some sort seems the likely culprit given how random it is
I got another cluster off ebay for £30 and swapped it over. Shouldn't be too hard as they have to come out for bulb changes.
Looks like the cars just discovered it's French :D
If it is solder cracking then most places will want to replace rather than repair, the solder can crack if they've used cheap solder so the only way to repair it would be remove all the old solder and then resolder with better solder. Might also get away with simply reflowing the solder but all this would take time and patience.
Mechanic just rang me and asked me if the cluster had been repaired before because it had been glued in and was difficult to remove. I said I wasn't aware of any cluster repair and I've had the car since 51000 miles in 2007. He said some solder was cracked on the back which they've now resoldered and needs me to take the car and use it to see if the problem is fixed. He said he had a similar problem on a 206 the other week and soldering fixed it. He said if it mine still does the same thing, then we'll sort out a second hand cluster on monday. So I'm going to go pick my car up and hope for the best!
Take a Sat Nav/phone with GPS and a speed app with you for the journey. If the speedo stopped working then at least you can tell your speed from that (it's what I had to use on my old car)
Hah yeah, I thought to do the same thing. I use google satnav built into my phone but it doesn't register speed. Any app I can download to show that?
My mum has one of these and had the same issue, she needed a new binnacle and it was a dash out job. Not much change from £500 at a local indi.
Why would you pay someone £500?!? Replacment clusters can be had for as little as £15 and after a quick google it looks like a 5 minute job requiring no more tools than a pair of small screwdrivers.
looks simpler than an air filter swap.
I'm in the wrong job!
I'm sure that is what she said, happened just a few weeks into ownership. I will give her a call to double check.
You were correct, sir, soldering seems to have fixed it! Not a single error during several long distance journeys over the weekend.
Also, my fuel gauge is working consistently now. All the time I thought a sensor was dodgy in the fuel tank, but it was the cluster not working properly.
Only 40 quid for an hours labour plus VAT at my local romanian run garage. :) They've done some pretty decent work for me at good prices over the last year.
When most garages are charging in excess of £70 to £80ph, these guys are staying competitive and always able to take my car to look at the same or following day.
