- 14 Jul 2013
- UK
Hi guys spec is in my sig. I currently have my 3570k at 4.5Ghz stable after a few hours of several P95 testing, temps hit a max of 77*c under 100% load.
I have all the settings in the bios set to auto, turbo boost is off and multiplier set at x45. All energy saving/down clocking idle settings still auto/active. Volts get reordered at 1.308 under 100% load in CPUZ and HWMonitor.
Now it seems if I use the offset voltage to decrease the voltage by 0.010 I get BSOD. If I up the multi to 46 I also get the BSOD.
Now im guessing unless I start going into more advanced manual settings etc then this is the sweet spot for my chip? Less voltage = BSOD, more multi and voltage = BSOD.
Any help or comments much appreciated.
CPUZ Validation - http://valid.canardpc.com/2sbtp7
