So last weekend I was replacing my kitchen sink tap. It's a monobloc design and it was directly connected to the pipework with copper pipe only, no flexi hoses and no isolation valve either (other than mains).
I thought it would be a good idea to fit a couple isolation valves before fitting the new tap which came with flexi hose fittings. I decided where to cut the existing cold and hot water supply pipes and did the cold one without problem.
When I went to do the hot water one though, this happened:
As you can see, it basically fell over. The only thing keeping it upright before was the tap itself.
I decided to do a temporary botch and carry on with the tap replacement:
What would a better permanent fix be? Bear in mind the only plumbing I've ever done before is changing the bits inside a cistern so go easy on me please guys
