Recommend me a Modular PSU
22 Feb 2006
Belfast
Hi Guys
I currently have an XFX850W Modular PSU and ever since I got the GTX 780, I can can hear a ticking noise coming from the PSU. I also get the occasional coil whine which others have experienced. I have decided to get a new PSU because of these noises and I was wondering could anyone recommend me a good Modular PSU for my system. My Spec is in my signature.
Your comments welcomed.
Chris
the clicking noise will be the fan hitting the plastic which sticks up underneath it
for one 780 you wont need 850w, 650w will be enough
YOUR BASKET
1 x Seasonic G series 650w '80 Plus Gold' Modular Power Supply £99.95
1 x NZXT Hale Power 90+ 650W '80 Plus Gold' Modular Power Supply £99.95
1 x EVGA SuperNova NEX 650W '80 Plus Gold' Modular Power Supply £95.99
1 x Be Quiet Power Zone 650W '80 Plus Bronze' Fully Modular Power Supply £89.99
Total : £395.47 (includes shipping : £8.00).
nzxt is made by superflower
Loving my seasonic x-850W so have to give it a recommendation here, not had it too long but no issues with O.C. system and dual gpus :)
What if I need more Hard drives? Will the 550 be enough?
Ia lready have an SSD and a Seagate Barracuda
Also, Im thinking of moving my system into an overclockers watercooled case..
like this one..
http://www.overclockers.co.uk/showproduct.php?prodid=WC-025-TL
Ive selected this PSU...
http://www.overclockers.co.uk/showproduct.php?prodid=CA-099-CS
Would this provide enough power?
Spend £20 more and get the Seasonic G 750W. It has better internal components, plus a longer warranty (5 years rather than 3).
YOUR BASKET
1 x Seasonic G series 750w '80 Plus Gold' Modular Power Supply £99.95
Total : £109.55 (includes shipping : £8.00).
as i said a 650w will be fine, and i wouldnt choose that corsair as already said above
and yes that seasonic will be perfect its the same price as the 650w anyway so yeh you might aswel get the 750w
Hi Guys, Sorry to bump this thread.
I have been told by some on the forum that 500w PSU would be enough for my system:
i7 3770k @ 4.5ghz
Antec Kuhler 920
Asus P8Z77-V Pro
16GB Ram
MSI GTX 780
1x 128gb ssd
1x 1TB Seagate Barracuda
1x DVD rewriter
1x Firewire PCI card
By that reckoning, would the following PSU be ok for my system?
http://www.overclockers.co.uk/showproduct.php?prodid=CA-000-SF&groupid=701&catid=123&subcat=2463
No point spending a premium on a fanless PSU when you can get a PSU with more wattage for a similar price. (Allows for future upgrades etc.)
Don't get a Corsair AXi PSU as they're made by cheap internals, compared to their cousin, AX (without the i) with seasonic internals.
Do you plan to have 2 cards in the future? If so, go for a 750/850w. If not, stick to a 550/650, as specced above.
Dye I'd rather spend the extra 20 and get the 750w seasonic g.. coz you never know what you might want getting!
besides less stress on PSU, less wattage used means less fan means less noise means happy you
sorry to jump on the thread but im just about to do a build and was wondering if a SuperFlower Leadex GOLD 750W Fully Modular "80 Plus Gold" Power Supply will power two gtx780, im only getting one for now but when time is right will get another, its gonna power a i7 4770k oc to 4.4/4.5 if it can , 2133mhz 8gb ram , h100i 2x 80mm fans 4x120mm fans and external dvd via usb 3.0 all going on a msi z87m in a parvum case, thanks for advice in advance
