Well I'm totally gutted I've just spent all day rebuilding my watercooled pc adding a extra block for a 7970, And now I'm getting a FF error code on my Asus Crosshair V Formula Z AMD 990FX. When I was leak testing the psu didn't like something. Possibly some stacked molex connectors or the motherboard bridge I was using. Now the pc won't boot in and chucks up the FF error code which I believe is the power supply and everything else seems to be working.
So I now need a new quiet psu and not sure which one to go for. I had a Coolermaster 850w modular before. But I suspect I need a little more power as the overclocks weren't to stable. What do you recommend?
Ideally no more than 190mm in length which also allows for the connectors on the end. Otherwise I might need to relocate a 240 rad or do some modding.
