Onkyo 605 remote
20 Aug 2008
I have an Onkyo 605 amp and on the remote controlled the volume control is broken. As far as I can see, this remote is no longer made and can only be bought from the USA.
I'm after the cheapest remote possible to replace it.
Please help.
the remote for my 805 has done the same - the conductive contact has worn away from the rubber membrane. Your tivo remote will control your onkyo's volume just fine :)
I've got a TX-SR605 remote that I never use, mine says RC-682M on it:
