Windows 8.1 will not sleep
7 Feb 2010
EDIT: SOLVED - see my final posts for all settings changed and two main culprits
Any suggestions to keep Windows 8.1 asleep?
These two are the only suggestions I've found and they haven't solved the issue:
1.) disable Wake on Pattern Match
2.) disable all autonomous 'Sleep' items in Advanced Power Settings
I've been trying to setup WoL (Wake on LAN) but my rig wouldn't remain asleep for more than 10 minutes. Option #1 cured the issue completely... until I purchased a Broadcom bluetooth dongle and the sleep problem reappeared immediately after instillation (I've even tried removing the dongle to no avail).
HHHEELLPPP!?
Can't be bothered to screenshot it but if you go into device manager.
Find the Bluetooth device. Right click and properties the device. Click on Power Management and untick 'Allow the device to wake the computer' as it's only happened since you've installed the Bluetooth device I'd say it was this that was waking your PC.
M.
I had the same issue, disable IPv6 on all of your network devices. That should fix it.
Thank you Malachi!
Just to be sure I didn't miss a setting, for each device I only disabled the four IPv6 options shown in these two windows.
Unfortunately it's still majestically waking, so were there any others?
Thanks a lot maccas, it was unticked already :(
Have you checked in task scheduler to make sure nothing else is waking your computer?
Hmm looks like there was one manual maintenance item with the allow to wake option selected. Lets see if that was it. I also disabled the other two shown in the image.
BY JOVE I THINK YOU'VE CRACKED IT JASE!
It remained in sleep for a full 20 minutes. Tonight will be the true test, hopefully it'll stay in sleep all night. I'll post an update tomorrow.
Thank you very much Jase and also to everyone else for offering advice.
Fingers crossed its now sorted. If you have windows media centre installed I know that also sometimes creates a scheduled task to wake the computer to update itself.
I would have presumed the task you listed above wouldn't start the computer as it's set to manual. I might be wrong though
Mate I have the same problem as you...
for some reason my PC which is sittung under my telly as a Media centre wakes itself up randomly.. cant for the like for me work out whats triggers it...
sometimes i will hit sleep and it will boot up again within five seconds...
Oh boy... it's still waking up and the event log doesn't show a thing. This is insane.
I'll take a look at the media centre settings.
For some reason tasks in Media Centre don't always show up in the event log for some reason. I had to wait for it to happen and track it down with the "powercfg –lastwake" command line.
More info here http://www.techsupportalert.com/content/how-fix-computer-keeps-waking.htm
Also if you have a IR remote, try uninstalling the drivers and reinstalling them.
I do have an IR remote but the drivers are built into windows... should i try deleting it from Device manager then letting windows re install?
The Media Centre task I am talking about is the mcupdate_scheduled task. This is usually set to wake the computer when WMC is installed.
