Projector for £300
3 Sep 2012
P town
Hi all, my brother is looking for a projector and I have no idea about them either, so here I am :p
Not really sure if anything decent can be had for this budget, if so please recommend. I'm guessing there'll be some full hd projectors for this price?
Also I'm guessing a screen will be required as well or will a wall do the job? As you can see I'm clueless on this topic :p
Thanks
Sorry but £300 isn't enough money to buy something worth owning for home cinema use, and certainly not if it has to stretch to a screen too.
Projector prices range from <£200 for the toys to over £100,000 for state of the art home cinema consumer projectors. The bulk of the market though is occupied by sub-£1000 projectors. Of those, there's a vast array of business projectors starting from around £250 that are okay for hooking up to the VGA port of a laptop. But they're no good for home cinema because they lack HDMI, and are not widescreen, and they have noisy fans, and poor colour fidelity, and very limited picture performance with video sources rather than data. IOW, you're buying something designed to do a different job. For home cinema they are fish out of water.
The cheapest business projector that'll do an okay job with video is the Optoma H180X. This is around £400. It has a HDMI input and the fan noise is tolerable (28dB). The Eco lamp life is very good at 6000hrs estimated. It's even widescreen 1280x720p 16:9 (native res is 1280x800 16:10). The only caveats are the relatively long throw distance compared to true home cinema projectors, and the basic video processing quality.
The relationship between screen size and projector position is often given as a throw ratio. This is simply one or two sets of numbers that are simple multipliers. If you had a throw ratio of 1:2 then for every 1 metre of screen width then you'd need 2 mtrs of throw distance. Since most projectors have a zoom lens to make the image bigger or smaller then you need two numbers: one to describe what happens when the lens is making the largest image and another for the smallest image setting. This Optoma has a throw ratio of 1.55-1.7 :1 So for a 1m wide image the throw distance will be 1.55m ~ 1.7m depending on the lens setting. A 2m wide image needs 3.1m ~ 3.4m throw distance.
Once you have the throw ratio you can estimate picture size at a given throw distance. The sum is a division: Throw distance divided by the throw ratio. eg. 3m throw /1.55 = 1.93m wide, and 3m throw /1.7 = 1.76m wide
The first of the true home entertainment/gaming projectors are around the £500 mark. The Optoma GT760 is around £550. It has better video processing to get more from movies, TV and consoles than a true business projector. The other thing it has is a very very short throw lens. There's no zoom this time. But this 1280x720 resolution projector needs just over 1m throw distance to make a 2m wide image. You put this projector down between you and the wall/screen rather than sitting it behind you.
If you want full 1080p native resolution as opposed to simply a compatibility mode then you need to up the budget to £600+ The BenQ W1070 and Optoma HD131Xe are both 1920x1080p native. Ball park costs are around £650.
All the above are entry level products in each class. They are not top-of-the-range or even mid-market. So while there may be cheaper general projectors, you're unlikely to find something technically better for the purpose of home entertainment/home cinema for significantly less. They each represent a minimum spend level to get acceptable performance.
Bear in mind too that you'll need a sound system, and probably some cabling (long HDMI as a minimum) on top of the projector cost. On the plus side, these are all fairly bright projectors so you don't need total blackout to get decent image brightness.
Thanks for your detailed reply.
What do you think of the Optoma HD 230X? It is full HD, has 2 HDMI ports and good reviews. Price is £300 but I read it was much more expensive previously.
£300 budget is enough to get a 2nd hand full HD projector.
I've got the Optoma HD230X. Got mine 2nd hand for just under £300. Worth every penny in my opinion.
As for a screen, you could always make your own :) I made mine (in my Project - man cave thread)
If you can get the Optoma HD230X for £300 new then happy days. You're right, it was sold for far more new originally which is why it wasn't even on the radar. I'm thinking it was up against the Benq W1070, so that would make it somewhere arount the £700-£900 mark.
link to that price please, i'd like one. :)
A secondhand optoma hd700x would be a good budget choice its only 720p but produces pictures almost as good as my 1080p model, theres one in the classifieds btw.
As for the screen i used to use a white blavkout blind that worked a treat. Unless your wall is white and free from bumps and texture then it wont look very good.
I think he'd struggle to get one new for that price.
(if you can OP, link! As I'll have a second one for the kitchen!)
I paid £500 18 months ago for an Optoma HD20-LV ex demo from Richersounds, had 300 hours on the bulb. Pretty impressed with the quality. I think rrp was about £700-750 so Worth keeping an eye on richersounds clearence
Optoma HD20/HD200X or Optoma HD23/HD230X are probably the most popular choice for the £300 second hand market. All full 1080p PJ's You could spend around £100 less and get a used 720p optoma HD65, but i would go for 1080p personally.
Mitsubishi HC3800 or Mitsubishi HC5000 also spring to mind for the same price. Both 1080p.
Keep an eye on here http://www.avforums.com/forums/tv-projector-classifieds.198/. Some bargains to be had.
Something ex-demo or second hand would be your best bet, I currently use an Epson EH3500 which is excellent and they can be had for not far off your budget these days. I'm sure you could find something on AVF?
