I bought a Mitsubishi Galant 2.0 Auto, and the seller said that it uses fuel due to the Air Flow Sensor, apparently this was diagnosed via the on board engine management system. The light is NOT on.
Now I ran a test, albeit only a small one to get an accurateish reading. I ran it to the fuel light coming on, put £20 in @ 127.9 per litre (15.63 litres?). I got 90 miles until the light came back on. I then put another £20 in and this time only got 70 miles until the light. Driving is the same every day, to work and back. Same traffic conditions. Looks like it works out to around 20 to 26mpg, Parkers seems to think around 30mpg for this car (1998 2.0 GLS Auto with Air Con). Currently trying a full tank to empty.
My route to work goes 30 to 40 to 30 to 40 and finally to 50mph limits. With roundabouts, traffic lights and dual carriageways, approx. 5 miles each way. I try to use Cruise Control where possible and avoid heavy breaking and hard acceleration.
Could the Air Flow sensor be at fault? There are no problems in the running of the car at all. Certainly none I may expect with a dodgy sensor (my last car ran lumpy with a dodgy air flow sensor)
Thanks in advance.
Thanks in advance.
