Apart from the tattered bashed up box that I got in my delivery I'm less than impressed with the overclockability of the card. At this present time I'm stuck with 1125mhz and a memory clock of 1600. I have yet to test a higher memory clock but the core is lacking and this is coming down to the volts!
Whenever I went over 1125 I'd get artifacts or driver has not responding errors and looking at my voltages I can see they were not very stable. So I went into Msi Afterburner, unlocked the voltages and tried to see what I could get out of the card.
According to many reviews of this card they all attained between 1.25v and 1.3v however it seems that I and a lot of other buyers not reviewers are stuck with a max volt of about 1.2v or much lower in apps like Furmark. Those in reviews to get atleast 1150 or higher on the core used 1.25v and up to 1.3v.
I was playing battlefield 4 and the volts went up to about 1.21 but quickly vrooping to 1.18v (53C-58C). In furmark and kombuster the volts are only maxing out at 1.156v! In such I'm very dissapointed in the attainable voltages and in reading other forums it also seems that for some reason MSI have put in a safety limit for customers. Oh and unlike the reviewers, you can't overclock the memory volts AT ALL!
Currently I'm set as
Fan 85%
Volts - 100mv+
Power Limit - +20%
CORE - 1125MHZ
MEM - 1600MHZ
No I know why they were on offer
ps I do understand that every card is different, but unless I can try for higher volts I'll never know!
Fan 85%
Volts - 100mv+
Power Limit - +20%
CORE - 1125MHZ
MEM - 1600MHZ
